mike_east
coregen fails with ICON 1.06a
I can't generate ICON 1.06a IP with ISE 14.07 on Linux. However, ICON 1.05a generate fine, as does other IP's i've tried.
coregen.log shows:
Customize and GenerateINFO:sim:172 - Generating IP...
Applying current project options...
Finished applying current project options.
Customizing IP...
Release 14.7 - Xilinx CORE Generator IP GUI Launcher P.20131013 (lin64)
Copyright (c) 1995-2013 Xilinx, Inc.  All rights reserved.
Finished Customizing.
Generating IP...
Configuring files for chipscope_icon root...
WARNING:coreutil - Failed to generate file: chipscope_icon_xmdf_tcl
       invoked from within
   "deliverEJava [getComponentName] {}"
       (procedure "components::chipscope_icon::pre_generation" line 52)
       invoked from within
   "$PreGenerationTargets"
       (procedure "::xilinx::sim::generation::generatePsfCore" line 55)
       invoked from within
   "::xilinx::sim::generation::generatePsfCore {chipscope_icon_v1_06_a}
   {chipscope_icon} {ALL}"ERROR:sim - Failed to generate file: chipscope_icon_xmdf_tcl
ERROR:sim - Error found during generation.
I've tried the solution in AR# 33073 to no avail.
Any help most welcome!
Mike
balkris
These errors are caused by a long directory name.
To work around this, reduce the length of the directory path that the cores are being generated in.
For ChipScope inserter, this is the target directory for the output netlist.
Check this ARs as well
https://www.xilinx.com/support/answers/52787.html
Thanks and Regards
Balkrishan
mike_east
Thanks Balkrishan,
Does that limitation apply to Linux?
Either way, I tried to create ICON with a clean project in /tmp/x and get the same issue:
mike@bld:/tmp/x$ coregen -p .
Release 14.7 - Xilinx CORE Generator P.20131013 (lin64)
All runtime messages will be recorded in /tmp/x/coregen.log
Welcome to Xilinx CORE Generator.
Help system initialized.
The IP Catalog has been reloaded.
Opening project file /tmp/x/.
Customizing IP...
Generating IP...
invoked from within
invoked from within
invoked from within
Saved CGP file for project 'coregen'.
Closed project file.
Other suggestions?
Mike
runyili
Hi, I have met the same problem, Did you solve this problem?
mike_east
Unfortunately not.
If i recall correct i solved it by using an older version of ICON.
Balkris assertion that long filenames was the cause was incorrect, as shown in my reply above.
Mike
finish0404
Hi : mike_east
How did you use older version of ICON or ILA?
Did you use older ISE version?
Or have the other way that can't change version of ISE?
mike_east
I used 14.7.
I think I enabled "show all versions" or something like that in coregen. Don't have it available now, so i cant check.
