generating VHDL cores for chipscope ILA and CON
      I generated chipscope cores using core generator in ISE14.4. But i find that these are in verilog. When i check the project settings in chipscope i see that only verilog option is present no VHDL. But my design is VHDL so it will be god if i can generate VHDL cores.
thanks for the support
waris
Re: generating VHDL cores for chipscope ILA and CON
Please try the below steps:
1. Select the Top Module of your design in ISE Project Navigator and right click
2. Click on Design Properties
3. Scroll down and look for Preferred Language
4. Set it to VHDL
Debraj
Scholar pratham
HI,
Do check your design properties and check prefered language it should be VHDL if you want to  generate chipscope core in VHDL.
Prathamesh
-Pratham
I confirmed in the project settings of core generator. There is no option of VHDL . Only verilog?
4. Set it to VHDL
Debraj
dear debraj.
                       Yes i checked and it was verilog . I have changed it t VHDL. Will try tommorrow to generate in Coregenerator with this setting.
