Observer tstone_sz
how can i use chipscope in vivado with the edf file
hi , i 'm using synplify to synthesis our project, then using the edf to vivado .
     i searche ug936,but can't found how to setup the ila with vivado, do you have any comments?
Re: how can i use chipscope in vivado with the edf file
Please refer to Lab 4: Using Synplify Pro Synthesis Tool and Vivado for Debugging a Design (page 38) of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug936-vivado-tutorial-programming-debugging.pdf
Thanks,Vijay
Observer tstone_sz
in synplify_pro,, we can edit *.prj to add the filelist at the different directory, can vivado do it?
