read & write on FSL bus
hi,
I added an special multiplier on fsl bus,  it takes some operand and return some others.
all operands MUST be wrritten and all results  MUST be read, if no, then next time hardware will not work correctly.
I wrote a macro to work with that hardware :
#define  fsl_fpu64( a,  b, c, cmd, status  );\
     write_into_fsl(    cmd                                , 0);\
     write_into_fsl(*( (unsigned int *)(void *)(&a))    , 0);\
     write_into_fsl(*( (unsigned int *)(void *)(&a) + 1), 0);\
     write_into_fsl(*( (unsigned int *)(void *)(&b))    , 0);\
     write_into_fsl(*( (unsigned int *)(void *)(&b) + 1), 0);\
     read_from_fsl(*( (unsigned int *)(void *)(&c))     , 0);\
     read_from_fsl(*( (unsigned int *)(void *)(&c) + 1 ), 0);\
     read_from_fsl( status                               , 0);\
// a and b and c are double precision.
it works OK when compiler optimization is off but whenever I turn it on, it does not work good.
I guess optimization clear away something, ?
I also tried below ASM code but nothing changed :
    asm volatile( \
    "put\t%3,rfsl" stringify(0) "\n\t" \
    "put\t%4,rfsl" stringify(0) "\n\t" \
    "put\t%5,rfsl" stringify(0) "\n\t" \
    "put\t%6,rfsl" stringify(0) "\n\t" \
    "put\t%7,rfsl" stringify(0) "\n\t" \
    "get\t%0,rfsl" stringify(0) "\n\t" \
    "get\t%1,rfsl" stringify(0) "\n\t" \
    "get\t%2,rfsl" stringify(0) "\n\t" \
    : "=d"( *( (unsigned int *)(void *)(&c))       ), \
      "=d"( *( (unsigned int *)(void *)(&c) + 1 ) ), \
      "=d"( status                                   ) \
    : "d"(  cmd                                    ), \
      "d"(*( (unsigned int *)(void *)(&a))         ), \
      "d"(*( (unsigned int *)(void *)(&a) + 1)    ), \
      "d"(*( (unsigned int *)(void *)(&b))        ), \
      "d"(*( (unsigned int *)(void *)(&b) + 1)    )   ); \
this code also works OK when optimization is off but ........
thanks
I could solve problem by exact debuging of assembly code with help of mb-objdum .
and this problem was really instructive for me.
my hardware core on fsl bus returns a double precision number.
for reading result I read it in two 32 bit number like this
and place it in a double type variable
by this type of reading result compiler could not understand the CHANGE of varialbe  c,
and this cause problem.
thanks
This question is really more appropriate for the EDK or Embedded Processing boards.
But regardless, you should become familiar with the C keyword "volatile"
There are many related discussions here or can be found elsewhere with google.
Here's an AR:
http://www.xilinx.com/support/answers/16633.htm (3.1 EDK - There appears to be a bug in the ppc/mb compiler?? (The "volatile" keyword is possibly required in the declaration))
bt
thanks
I will continue in Proper Place in EDK section :
http://forums.xilinx.com/t5/EDK-and-Platform-Studio/software-Optimization-problem-for-a-hardware-on-FSL-bus/td-p/152976
I also test your solution but problem still is there,
may you please go there, I continue to explain my problem better there,
thanks
i am implementing dual microblaze processor using  fsl commn.,
 while using fsl macro it shows that line 3 does not execute
line 1 & 2 execute, while macro line is not...
as the console output display only lines 1 & 2 and dont  display line 3
code 1  (microblaze 0) :
#include <mb_interface.h>
#include <xutil.h>
#include <stdio.h>
#include "platform.h"
int main(void)
    int i = 0;
    print("Hello World\n\r");                  // line 1
    while(i<10)
        print("Hello......\n\r");             // line 2
        putfsl(i, 0);
        getfsl(i, 0);
        //xil_printf("pong %d\n\r", i);
        xil_printf("pong %d\n\r", i);          // line 3
code 2 (microblaze 1):-
#include <xutil.h>
#include <stdio.h>
int main(void)
    int i;
    print("22222222222  \n\r");             //line 4
    while(1)
        getfsl(i, 0);
        print("Hello World\n\r");             // line 5
        xil_printf("ping %d\n\r", i++);
        putfsl(i, 0);
even if code 2 is executed only line 4 is shown on uart and not line 5.
