ugly font in Vivado 2018.3 under Centos 7.6
Please see below picture. The font is very ugly and unclear. Do you know how to solve this problem?
The OS is Centos 7.6
Scholar dpaul24
Re: ugly font in Vivado 2018.3 under Centos 7.6
@jerry.yau,
From UG973 (v2018.3) December 14, 2018, I see that the supported versions are:
• CentOS 7.2, 7.3, 7.4, and 7.5 (64-bit)
• CentOS 6.7, 6.8, and 6.9 (64-bit)
It might be that Vivado is pending to be tested on Centos 7.6.
Alternatively play around with the 'Dispaly' settings to your satisfaction....
Porject Manajer --> Settings --> Tool Settings --> Display
FPGA enthusiast!
All PMs will be ignored
Hi @dpaul24 .
  Below picture shows you that Vivado running on another centos 7.6 computer. The font is very beautiful.Vivado_font1.png
These computers initially installed Centos 7.4. Then updated to 7.6. Same vivado version has a different result on computers so I don't know it is not cause that Vivado don't be tested on centos 7.6.
According to your reply, what parameter I need to try:
scaling
Display density.
Jerry Yau
Scholar dpaul24
@jerry.yau,
I made an educated guess. You have to play around with the 'Display' parameters.Try all permutations and combinations.
FPGA enthusiast!
Scholar watari
Hi @jerry.yau
It seems font cache issue or font issue.
I suggest you to make sure font cache.
Would you try "fc-cache" command on your CentOS 7.6 ?
Best regards,
Hi, @dpaul24.
I tried. don't work.
Hi @watari .
Just using "fc-cache" gets nothing:
fc-cache -v got:
/usr/share/fonts: skipping, existing cache is valid: 0 fonts, 41 dirs
/usr/share/fonts/abattis-cantarell: skipping, existing cache is valid: 4 fonts, 0 dirs
/usr/share/fonts/cjkuni-uming: skipping, existing cache is valid: 4 fonts, 0 dirs
/usr/share/fonts/default: skipping, existing cache is valid: 0 fonts, 2 dirs
/usr/share/fonts/default/Type1: skipping, existing cache is valid: 35 fonts, 0 dirs
/usr/share/fonts/default/ghostscript: skipping, existing cache is valid: 4 fonts, 0 dirs
/usr/share/fonts/dejavu: skipping, existing cache is valid: 21 fonts, 0 dirs
/usr/share/fonts/gnu-free: skipping, existing cache is valid: 12 fonts, 0 dirs
/usr/share/fonts/google-crosextra-caladea: skipping, existing cache is valid: 4 fonts, 0 dirs
/usr/share/fonts/google-crosextra-carlito: skipping, existing cache is valid: 4 fonts, 0 dirs
/usr/share/fonts/google-noto-emoji: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/jomolhari: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/khmeros: skipping, existing cache is valid: 3 fonts, 0 dirs
/usr/share/fonts/liberation: skipping, existing cache is valid: 16 fonts, 0 dirs
/usr/share/fonts/lklug: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/lohit-assamese: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/lohit-bengali: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/lohit-devanagari: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/lohit-gujarati: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/lohit-kannada: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/lohit-malayalam: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/lohit-marathi: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/lohit-nepali: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/lohit-oriya: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/lohit-punjabi: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/lohit-tamil: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/lohit-telugu: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/madan: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/nhn-nanum: skipping, existing cache is valid: 3 fonts, 0 dirs
/usr/share/fonts/open-sans: skipping, existing cache is valid: 10 fonts, 0 dirs
/usr/share/fonts/opensymbol: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/overpass: skipping, existing cache is valid: 8 fonts, 0 dirs
/usr/share/fonts/paktype-naskh-basic: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/paratype-pt-sans: skipping, existing cache is valid: 6 fonts, 0 dirs
/usr/share/fonts/sil-abyssinica: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/sil-nuosu: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/sil-padauk: skipping, existing cache is valid: 2 fonts, 0 dirs
/usr/share/fonts/smc: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/stix: skipping, existing cache is valid: 4 fonts, 0 dirs
/usr/share/fonts/thai-scalable: skipping, existing cache is valid: 4 fonts, 0 dirs
/usr/share/fonts/ucs-miscfixed: skipping, existing cache is valid: 23 fonts, 0 dirs
/usr/share/fonts/vlgothic: skipping, existing cache is valid: 1 fonts, 0 dirs
/usr/share/fonts/wqy-microhei: skipping, existing cache is valid: 2 fonts, 0 dirs
/usr/share/fonts/wqy-zenhei: skipping, existing cache is valid: 3 fonts, 0 dirs
/usr/share/X11/fonts/Type1: skipping, existing cache is valid: 13 fonts, 0 dirs
/usr/share/X11/fonts/TTF: skipping, no such directory
/usr/local/share/fonts: skipping, no such directory
/home/jerry/.local/share/fonts: skipping, no such directory
/home/jerry/.fonts: skipping, no such directory
/usr/share/fonts/abattis-cantarell: skipping, looped directory detected
/usr/share/fonts/cjkuni-uming: skipping, looped directory detected
/usr/share/fonts/default: skipping, looped directory detected
/usr/share/fonts/dejavu: skipping, looped directory detected
/usr/share/fonts/gnu-free: skipping, looped directory detected
/usr/share/fonts/google-crosextra-caladea: skipping, looped directory detected
/usr/share/fonts/google-crosextra-carlito: skipping, looped directory detected
/usr/share/fonts/google-noto-emoji: skipping, looped directory detected
/usr/share/fonts/jomolhari: skipping, looped directory detected
/usr/share/fonts/khmeros: skipping, looped directory detected
/usr/share/fonts/liberation: skipping, looped directory detected
/usr/share/fonts/lklug: skipping, looped directory detected
/usr/share/fonts/lohit-assamese: skipping, looped directory detected
/usr/share/fonts/lohit-bengali: skipping, looped directory detected
/usr/share/fonts/lohit-devanagari: skipping, looped directory detected
/usr/share/fonts/lohit-gujarati: skipping, looped directory detected
/usr/share/fonts/lohit-kannada: skipping, looped directory detected
/usr/share/fonts/lohit-malayalam: skipping, looped directory detected
/usr/share/fonts/lohit-marathi: skipping, looped directory detected
/usr/share/fonts/lohit-nepali: skipping, looped directory detected
/usr/share/fonts/lohit-oriya: skipping, looped directory detected
/usr/share/fonts/lohit-punjabi: skipping, looped directory detected
/usr/share/fonts/lohit-tamil: skipping, looped directory detected
/usr/share/fonts/lohit-telugu: skipping, looped directory detected
/usr/share/fonts/madan: skipping, looped directory detected
/usr/share/fonts/nhn-nanum: skipping, looped directory detected
/usr/share/fonts/open-sans: skipping, looped directory detected
/usr/share/fonts/opensymbol: skipping, looped directory detected
/usr/share/fonts/overpass: skipping, looped directory detected
/usr/share/fonts/paktype-naskh-basic: skipping, looped directory detected
/usr/share/fonts/paratype-pt-sans: skipping, looped directory detected
/usr/share/fonts/sil-abyssinica: skipping, looped directory detected
/usr/share/fonts/sil-nuosu: skipping, looped directory detected
/usr/share/fonts/sil-padauk: skipping, looped directory detected
/usr/share/fonts/smc: skipping, looped directory detected
/usr/share/fonts/stix: skipping, looped directory detected
/usr/share/fonts/thai-scalable: skipping, looped directory detected
/usr/share/fonts/ucs-miscfixed: skipping, looped directory detected
/usr/share/fonts/vlgothic: skipping, looped directory detected
/usr/share/fonts/wqy-microhei: skipping, looped directory detected
/usr/share/fonts/wqy-zenhei: skipping, looped directory detected
/usr/share/fonts/default/Type1: skipping, looped directory detected
/usr/share/fonts/default/ghostscript: skipping, looped directory detected
/usr/lib/fontconfig/cache: not cleaning unwritable cache directory
/home/jerry/.cache/fontconfig: cleaning cache directory
/home/jerry/.fontconfig: not cleaning non-existent cache directory
/usr/bin/fc-cache-32: succeeded
/usr/bin/fc-cache-64: succeeded
Scholar watari
hi @jerry.yau
Would you use "-f" option (force update) ?
Best regards,
Hi @watari .
  Thanks for your reply. However, don't work.
But I unset LANG, the fone is ok now. Here are the language settings now:
[jerry@jerry ~]$ unset LANG
[jerry@jerry ~]$ locale
LANG=
LC_CTYPE="POSIX"
LC_NUMERIC="POSIX"
LC_TIME="POSIX"
LC_COLLATE="POSIX"
LC_MONETARY="POSIX"
LC_MESSAGES="POSIX"
LC_PAPER="POSIX"
LC_NAME="POSIX"
LC_ADDRESS="POSIX"
LC_TELEPHONE="POSIX"
LC_MEASUREMENT="POSIX"
LC_IDENTIFICATION="POSIX"
LC_ALL=
Do you know why Vivado had ugly font when LANG is zh_TW.UTF-8?
B/R
Scholar watari
Hi @jerry.yau
According to your result, it's font issue.
Would you make sure the different between the followings ?
$ fc-list :lang=en
$ fc-list :lang=zh
Best regards,
Hi, @watari .
  Here you are.
ZH has 9 fonts and EN has 182 fonts. So how to let ZH has more fonts/
$ fc-list :lang=zh
/usr/share/fonts/wqy-microhei/wqy-microhei.ttc: 文泉驛微米黑,WenQuanYi Micro Hei:style=Regular
/usr/share/fonts/wqy-zenhei/wqy-zenhei.ttc: WenQuanYi Zen Hei:style=Regular
/usr/share/fonts/wqy-zenhei/wqy-zenhei.ttc: 文泉驛點陣正黑,WenQuanYi Zen Hei Sharp:style=Regular
/usr/share/fonts/cjkuni-uming/uming.ttc: AR PL UMing TW MBE:style=Light
/usr/share/fonts/wqy-microhei/wqy-microhei.ttc: 文泉驛等寬微米黑,WenQuanYi Micro Hei Mono:style=Regular
/usr/share/fonts/wqy-zenhei/wqy-zenhei.ttc: WenQuanYi Zen Hei Mono:style=Regular
/usr/share/fonts/cjkuni-uming/uming.ttc: AR PL UMing TW:style=Light
/usr/share/fonts/cjkuni-uming/uming.ttc: AR PL UMing HK:style=Light
/usr/share/fonts/cjkuni-uming/uming.ttc: AR PL UMing CN:style=Light
$ fc-list :lang=en
/usr/share/fonts/overpass/Overpass-Light-Italic.ttf: Overpass:style=Light Italic
/usr/share/fonts/ucs-miscfixed/5x8.bdf: Fixed:style=Regular
/usr/share/fonts/ucs-miscfixed/6x9.bdf: Fixed:style=Regular
/usr/share/fonts/open-sans/OpenSans-ExtraBold.ttf: Open Sans,Open Sans Extrabold:style=Extrabold,Regular
/usr/share/fonts/dejavu/DejaVuSansCondensed-BoldOblique.ttf: DejaVu Sans,DejaVu Sans Condensed:style=Condensed Bold Oblique,Bold Oblique
/usr/share/X11/fonts/Type1/c0633bt_.pfb: Bitstream Charter:style=Bold Italic
/usr/share/fonts/liberation/LiberationSans-Regular.ttf: Liberation Sans:style=Regular
/usr/share/X11/fonts/Type1/c0649bt_.pfb: Bitstream Charter:style=Italic
/usr/share/fonts/dejavu/DejaVuSans-Oblique.ttf: DejaVu Sans:style=Oblique
/usr/share/fonts/default/Type1/n019044l.pfb: Nimbus Sans L:style=Bold Condensed
/usr/share/fonts/default/Type1/p052003l.pfb: URW Palladio L:style=Roman
/usr/share/fonts/default/Type1/c059036l.pfb: Century Schoolbook L:style=Bold Italic
/usr/share/fonts/default/Type1/n019063l.pfb: Nimbus Sans L:style=Regular Condensed Italic
/usr/share/fonts/gnu-free/FreeSansBoldOblique.ttf: FreeSans:style=Bold Oblique,Gras Italique
/usr/share/X11/fonts/Type1/c0632bt_.pfb: Bitstream Charter:style=Bold
/usr/share/fonts/default/Type1/n019064l.pfb: Nimbus Sans L:style=Bold Condensed Italic
/usr/share/fonts/google-crosextra-caladea/Caladea-BoldItalic.ttf: Caladea:style=Bold Italic,Italic
/usr/share/fonts/dejavu/DejaVuSans-BoldOblique.ttf: DejaVu Sans:style=Bold Oblique
/usr/share/fonts/gnu-free/FreeSerifItalic.ttf: FreeSerif:style=Italic,Kursiv
/usr/share/fonts/ucs-miscfixed/7x13.bdf: Fixed:style=Regular
/usr/share/fonts/default/Type1/n019043l.pfb: Nimbus Sans L:style=Regular Condensed
/usr/share/X11/fonts/Type1/UTRG____.pfa: Utopia:style=Regular
Scholar watari
Hi @jerry.yau
I'm not familiar with Traditional Chinese.
But I suspect the following fonts.
Would you make sure them ?
BTW, here is my result. But I have not use zt as LANG yet.
$ lc-list :lang=zh
文泉驛正黑,WenQuanYi Zen Hei,文泉驿正黑:style=Regular
文泉驛等寬正黑,WenQuanYi Zen Hei Mono,文泉驿等宽正黑:style=Regular
文泉驛點陣正黑,WenQuanYi Zen Hei Sharp,文泉驿点阵正黑:style=Regular
Best regards,
