unable to export asii file using chipscope
I am using ISE12.1  and the chipscope in win7.  The JTAG chain connects three FPGA chips.  I can load a file via chipscope successfully.
          When I click the"select a new file" button,no reaction.
          When I want to export a ASII file,it always display that:invalid  file name.Then ,nothing hanppened.
So,what I should do to export my waveform data.
Click on the waveform window (i..e, highlight) in chipscope analyzer and then go to File --> Export
Vinay
The problem is still not been fixed.
I click on the waveform window (i..e, highlight) in chipscope analyzer and then go to File --> Export .But,still dispaly:INFO:invalid export file name.Then,nothing happen.
What should I do ??
