vivado 2015.3 KU060-1517-e-2 jtag download fail
Hi!
  everyone! i used jtag download bit files to fpga. some bits file can work. some download fails. i don't know
why.
ERROR: [Labtools 27-3165] End of startup status: LOW
program_hw_devices: Time (s): cpu = 00:00:27 ; elapsed = 00:00:25 . Memory (MB): peak = 758.047 ; gain = 0.000
ERROR: [Common 17-39] 'program_hw_devices' failed due to earlier errors.
 i dump the register in the two situation。table.xlsx is failed.
 somebody help !
thanks!
Re: vivado 2015.3 KU060-1517-e-2 jtag download fail
Hi @nujnal,
Direct RSA bitstream configuration via JTAG is not supported in the 2015.3 version of Vivado Device Programmer.
Please check the following answer record.
http://www.xilinx.com/support/answers/65328.html
Thanks,Vijay
Are you using the same board to dump all bit files?
Can you please tell us what setting you are changing while generating two bit files i.e. failing and passing?
Please open implemented design for both passing and failing bitfile and run following command
report_property -all [current_design]
please share the output.
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
Hi @nujnal
Did that help?
Thanks,Vijay
sorry, after we changed source code,new implemented bits file can work, so i had not fouse on the problem。
Yes,we dumped the two files in the same board.
we did not change any settings, but just changed verilog source code.
the project didn't saved. you konw after the bit file didn't not work, we changed source code implemented again,new bits can work.
What block of source code you have changed? unsaved project/changed code seems to be creating issue. Do you still have any question about this?
-Shreyas
