2013.3 Getting error License feature [HLS_BETA] is not available
 I've installed 2013.3, and the 30 day evaluation license from web site.
 In GUI mode, i get this error:
----X----
@I [LIC-101] Checked out feature [VIVADO_HLS]
@I [HLS-10] Running ..........
@I [LIC-101] Checked in feature [VIVADO_HLS]
@E [LIC-104] License feature [HLS_BETA] is not available.
command 'license_checkout' returned error code
-----X--------
In CLI mode,  HLS_BETA  checkout it not attempted, so things seem to work fine.
How can I run the 2013.3 Vivado HLS in GUI mode with 30 day trial licensing key ?
TIA.
Re: 2013.3 Getting error License feature [HLS_BETA] is not available
Hi Vardhan,
Could you please share the xinfo file so that I can check.
You can generate xinfo file by following below steps:-
 Start--> All Programs -->Xilinx Design tools-->ISE Design Suite14.x--> Accessories -->  Xinfo System Checker.
After you run “Xinfo System Checker”, the Xinfo.txt report will be generated and saved in your C (Home Drive):\Xilinx\14.x\ISE_DS\common folder, as a text file (.txt)
Did you generate a Vivado_HLS Evaluation License from www.xilinx.com/getlicense? Can you paste the content of your license here.
Debraj
