Observer jirhus
Estimated clock are greater than target
I'm new in Vivado HLS and a want to design easy filter for image processing. The HLS component is connected throught AxiStream IN and AxiStreamOUT.
When I run Synthesis without pipelining (the result is in first picture) the estimated clock is  3.68 ns, but interval is 3 clocks. I need result every clock -> II=1 in pipeline. Unfortunately with pipeline directive the estimation clock are greater then target (Picture 2). Is possible design that in interval 1 clock with greater latency and resources?
Observer jirhus
Re: Estimated clock are greater than target
I have solved my problem.
The problem was in multiple writing values into EOL a SOL counters and there was problem with pipelining in target clock.
that's strange because it met timing in the non-pipelined version; can you post your design and directives used?
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
Observer jirhus
There is my design:
#include "ap_int.h"
#include "ap_shift_reg.h"
#define FRAME_WIDTH 20
#define FRAME_HEIGHT 10
#define MASK_WIDTH 3
#define BUFFER_DEPTH 2 * FRAME_WIDTH + MASK_WIDTH
typedef struct {
	ap_uint<10> data;
	ap_uint<1> user;
	ap_uint<1> last;
} MyAxiStream;
void sobel(MyAxiStream *Image_IN, MyAxiStream *Image_OUT){
	#pragma HLS PIPELINE II=1
	#pragma HLS INTERFACE axis port=Image_IN
	#pragma HLS INTERFACE axis port=Image_OUT
	static ap_shift_reg<ap_uint<10>, FRAME_WIDTH-MASK_WIDTH> buffer1;
	static ap_shift_reg<ap_uint<10>, FRAME_WIDTH-MASK_WIDTH> buffer2;
	static ap_uint<10> a,b,c,d,e,f,g,h,i;
	static ap_uint<12> SOFcounter = 0;
	static ap_uint<12> EOLcounter = 0;
	static ap_uint<1> valid = 0;
	ap_uint<10> result = 0;
	ap_uint<1> last = 0;
	ap_uint<1> user = 0;
	//read and shift:
	i = h;
	h = g;
	g = buffer1.shift(f, FRAME_WIDTH-MASK_WIDTH-1, true);
	f = e;
	e = d;
	d = buffer2.shift(c, FRAME_WIDTH-MASK_WIDTH-1, true);
	c = b;
	b = a;
	a = Image_IN->data.to_int();
	last = Image_IN->last.to_int();
	user = Image_IN->user.to_int();
	//pixel counter
	SOFcounter++;
	EOLcounter++;
	if(user == 1){
		SOFcounter = 1;
		EOLcounter = 1;
	//apply mask
	result += 2 * i;
	result += 1 * h;
	//result.data += 0 * g;
	result += 1 * f;
	//result.data += 0 * e;
	result += -1 * d;
	//result.data += 0 * c;
	result += -1 * b;
	result += -2 * a;
	//set outputs - start of frame
	if(SOFcounter ==  2*FRAME_WIDTH+MASK_WIDTH){
		user = 1;
		valid = 1;
	//set outputs - end of line
	if(EOLcounter == FRAME_WIDTH){
		last = 1;
		EOLcounter = 0;
	if(valid == 1){
		Image_OUT->data = result;
		Image_OUT->user = user;
		Image_OUT->last = last;
Observer jirhus
