How to implement such function in HLS C++ ?
Hello,everybody.
vivado2015.4.1.
I want to implement such function-------
Every period there is a sync signal.
Then I begin to read M data from RAM.
After N periods, I got M*N data samples.
I need to use this entire M*N matrix for my next algorithm.
I know a for-loop could read data from RAM to local memory,
but it is only one dimension.
I really do NOT know how to write code
to read and save the data to a two-dimension matrix in HLS.
Please help me !
Teacher muzaffer
Re: How to implement such function in HLS C++ ?
a two dimensional array is just a linear array of memory where you use two different indices to get at the data you want. Basically if you have indices i, j with M with the maximum value of i, to get at any arbitrary element you can use address = i + j * M.
In any case, check whether you need all the data in the array before your "next algorithm" can proceed. Usually you need a number of lines where the number is less than N so you don't need to wait for all the N lines.
Scholar u4223374
Have a look at the image processing examples (eg. XAPP 1167). After all, an image is a 2D array of numbers, just like a matrix.
What you'll find is that in RAM images are stored as long 1D arrays, and for streaming they're treated as 1D arrays with a marker to indicate each line (TLAST, set on the last bit of each line).
