Is DATAFLOW possible in this case?
The case is the following:
void top( data_t input_data[], data_t output_data[] )
	data_t buffer[];
	for ( index_t n = 0; n != N; n++ )
		fill_buffer ( input_data, buffer );
		consume_buffer ( buffer, output_data );
I would like to use the DATAFLOW directive for the body of the loop - first wrapping the loop body in a function and applying the DATAFLOW directive in this new function.
Is this possible?
If it is not possible, is there another way of achieving the same result?
Cheers,
Panos
Without proper software tools the hardware is unusable no matter how good and well designed it is.
Re: Is DATAFLOW possible in this case?
Add "dataflow" to the body of the loop. HLS supports dataflow on loops. Like:
#pragma HLS dataflow
brucey
Scholar u4223374
I think it'll work better if "buffer" is declared inside the loop (and therefore inside the function). HLS can be picky about that sort of thing.
Apart from that, it should work as long as fill_buffer and "consume_buffer" use appropriate access patterns - every element gets read/written exactly once, sequentially.
brucey
