Transfer the HLS generated Verilog-HDL to Altera's FPGA
Accepted Solution Solved
Accepted Solution
Hi all,
I'm Hiroki Nakahara working at Ehime University, Japan.
Today, I tried to generate the HDL codes from the Vivado HLS.
The target device is the Artix7 which is used in the Nexys4 DDR board.
I wrote the C-code which converts the RGB color data into the HSV color ones.
Next, I used the Vivado HLS to generate the Verilog HDLs.
Then, I transfer them to the Altera's Quartus II version 14.0 sp1.
Believe it or not, the Quartus II successfully synthesized the HSV converter without no-warnings.
After that, I configured the MAX10 FPGA, and the board runs without any troubles!
My question is "Is it possible to use the Vivado HLS in order to a front-end of the Quartus II?".
I'm afraid that this transfer becomes a violation of the Xilinx's Vivado HLS license terms.
Hiroki
Re: Transfer the HLS generated Verilog-HDL to Altera's FPGA
you can read the agreement
http://www.xilinx.com/support/documentation/sw_manuals/end-user-license-agreement.txt
Thanks and Regards
Balkrishan
All Replies
Xilinx Recommend to use Xilinx Device for HLS flow . We have not tested such flow at our end.
So not sure if you may stuck at any point the future.
I think 1-2 design may not enough to valid such flow
I would recommend not use such flow with critical application design
Thanks and Regards
Balkrishan
Thank you very much for your kindless reply.
How do you think a violation of the Xilinx's Vivado HLS license terms about this topic?
Bests,
Hiroki
Thanks and Regards
Balkrishan
回复: Transfer the HLS generated Verilog-HDL to Altera's FPGA
Tools are getting smarter.
Array to RAM conversion may work in both X and Altera tools.
I am not sure how it goes when clock synthesizers and DCMs are involved.
Re: Transfer the HLS generated Verilog-HDL to other FPGA's
[ Edited ]
Use of Xilinx software on non-Xilinx devices is clearly prohibited in the end user license agreent (the relevant clause is copied below):
4.    Restrictions.
    (a)    Special Use Restrictions.  No right is granted hereunder to use the Software or any Bitstream generated by use of the Software to program or develop designs for non-Xilinx Devices;
Bests,
Hiroki
Cheers,
Jim
"No right is granted hereunder to use the Software or any Bitstream generated by use of the Software to program or develop designs for non-Xilinx Devices"
Austin Lesea
Principal Engineer
Xilinx San Jose
