Why HLS is not implementing a pure-combinatorial fixed-point multiplication?
I am making a comparison of a simple multiplication using floating-point and fixed-point formats. The code is the next, where I only change the in_t and out_t types to either fixed or floating-point formats:
void simple_operations(const in_t mat[2], out_t invOut[2])
    invOut[0] = mat[0] * mat[1];
I am a bit confused because when using the same amount of bytes in both formats (32- and 64-bits), both fixed-point versions have more latency than their floating-point counterparts. See next picture:
Does anyone know why is this happening? Because using a pure-combinatorial approach it should output the result in zero or one clock cycles. But apparently, this is not the case and I don't know why.
Many thanks,
Cerilet
Scholar austin
Re: Why HLS is not implementing a pure-combinatorial fixed-point multiplication?
c,
One stage of logic, with a register, may operate in some families in as little as 1.5 nanosecond.  But the required number of stages for a full multiply is not going to be one stage (not unless you have a 128 bit look up table 64 bits wide).
The tools try their best to use the resources effectively.  You can ask for less delay, and see what happens.
Also a 64 bit floating point multiply is in no way equivalent to 64 bit fixed point.  Different animals.
Latency increases as pipeline registers are required to meet timing.
Austin Lesea
Principal Engineer
Xilinx San Jose
Scholar austin
c,
Austin Lesea
Principal Engineer
Xilinx San Jose
Thanks for your answer, Austin.
I actually thought about that and by increasing the clock period, the compiler managed to execute the multiplication with 0 latency. Here the results:
I know the difference between fixed- and floating-point variables, but in my study in which a matrix multiplication is a small part of it, I want to point out the main strengths and weaknesess of both implementations. But actually, I was expecting faster execution times using fixed-point variables. Big surprise!
Thanks again,
Cerilet
