Observer zhengjia
about hls opencv function interface
I used the function of resize, Now ,I want set the function interface m_axi. but it failed.
My code is following
typedef hls::Mat<SRC_HEIGHT, SRC_WIDTH, HLS_8UC3> SRC_IMAGE;
typedef hls::Mat<DST_HEIGHT, DST_WIDTH, HLS_8UC3> DST_IMAGE;
void my_hls_resize(SRC_IMAGE& src_axi, DST_IMAGE& dst_axi, int src_rows, int src_cols,int dst_rows,int dst_cols);
#pragma HLS INTERFACE m_axi  port=dst_axi offset=slave bundle=dst
#pragma HLS INTERFACE m_axi  port=src_axi offset=slave bundle=src
#pragma HLS dataflow
//hls::AXIvideo2Mat(src_axi, imag_0);
hls::Resize(src_axi,dst_axi,interpolation=HLS_INTER_LINEAR );
The errors are:
ERROR: [XFORM 203-801] Stream port 'src_axi.data_stream[0].V' (top.cpp:3) has invalid interface mode 'm_axi' (top.cpp:6:1). Stream port only supports ap_hs, ap_fifo and axis modes.
ERROR: [XFORM 203-801] Stream port 'src_axi.data_stream[1].V' (top.cpp:3) has invalid interface mode 'm_axi' (top.cpp:6:1). Stream port only supports ap_hs, ap_fifo and axis modes.
ERROR: [XFORM 203-801] Stream port 'src_axi.data_stream[2].V' (top.cpp:3) has invalid interface mode 'm_axi' (top.cpp:6:1). Stream port only supports ap_hs, ap_fifo and axis modes.
ERROR: [XFORM 203-801] Stream port 'dst_axi.data_stream[0].V' (top.cpp:3) has invalid interface mode 'm_axi' (top.cpp:5:1). Stream port only supports ap_hs, ap_fifo and axis modes.
ERROR: [XFORM 203-801] Stream port 'dst_axi.data_stream[1].V' (top.cpp:3) has invalid interface mode 'm_axi' (top.cpp:5:1). Stream port only supports ap_hs, ap_fifo and axis modes.
ERROR: [XFORM 203-801] Stream port 'dst_axi.data_stream[2].V' (top.cpp:3) has invalid interface mode 'm_axi' (top.cpp:5:1). Stream port only supports ap_hs, ap_fifo and axis modes.
So, how can I set the src_axi and dst_axi to m_axi interface? please help me.
