Observer kevin_pang
hls::stream is read while empty, simple axi4-stream problem, hls newbie, need help!
Hi, everyone!
I am working on Vivado HLS.  and I want a simple function, 1080p axi4-stream input( raw input, one clk with two pixels), and i want a 720p axi4-stream output, just using simple cropping method.  But it keeps putting the warning like below: (the source file is in the attachment)
"WARNING: Hls::stream 'hls::stream<ap_axiu<24, 1, 1, 1> >.2' is read while empty, which may result in RTL simulation hanging."
I search the forum, and some suggest that :
while(!my_stream.empty()) { /*do something*/ }
but I still could solved it!
Any help could be appreciated!
the code is showed below:
#include <hls_video.h>
#include <hls_stream.h>
#include <ap_axi_sdata.h>
#include <iostream>
#include "hlsCrop.h"
using namespace std;
// input image 1920 x 1080
// output image 1280 x 720
// compliant to axi4-stream interface video protocol
void hlsCrop(axi_stream_t &RawIn, axi_stream_t &RawOut){
#pragma HLS INTERFACE s_axilite port=return
#pragma HLS INTERFACE axis port=RawIn
#pragma HLS INTERFACE axis port=RawOut
int rowIdx, colIdx;
For_RowScan: for(rowIdx = 0; rowIdx < IN_IMG_MAX_ROWS; rowIdx++) {
bool rowVld = ((rowIdx >=0) && (rowIdx <OUT_IMG_MAX_ROWS));
For_ColScan: for(colIdx = 0; colIdx < IN_IMG_MAX_COLS; colIdx++) {
#pragma HLS PIPELINE II=1
pix_t inPix;
while(!RawIn.empty()) {
inPix = RawIn.read();
if(1 == inPix.user) {
rowIdx = 0;
colIdx = 0;
bool colVld = ((colIdx >=0) && (colIdx <OUT_IMG_MAX_COLS));
if(rowVld && colVld) {
pix_t outPix;
outPix.data = inPix.data;
//outPix.keep = inPix.keep;
//outPix.dest = inPix.dest;
//outPix.id = inPix.id;
//outPix.strb = inPix.strb;
outPix.last = (colIdx == OUT_IMG_MAX_COLS);
outPix.user = ( (rowIdx == 0) && (colIdx == 0) );
RawOut.write(outPix);
return;
Re: hls::stream is read while empty, simple axi4-stream problem, hls newbie, need help!
Hey @kevin_pang,
That's excellent! I'm glad you were able to find the issue!
Consider marking one of the posts in the thread as the solution so we know the thread is solved.
Nicholas Moellers
Xilinx Worldwide Technical Support
Hey @kevin_pang,
What's your testbench look like? You're reading more values from your stream than you have written. What did you write to the stream in the testbench? I'd also be concerned about this line:
rowIdx = 0;
colIdx = 0;
since that could cause your entire loop to restart. Does your testbench set the .user bit unexpectedly?
Consider running your simulation in debug mode with some breakpoints or just adding some print statements. Check how many reads and writes actually occur. Where does the simulation not match your expectations?
Nicholas Moellers
Observer kevin_pang
@nmoeller, Thank you very much for your answer. It is really helpful.
I have worked it out according to your hints.
I have made several mistakes, and one of it is "outPix.last = (colIdx == (OUT_IMG_MAX_COLS -1) );" , I generate the wrong outPix.last member. Now it works.
the testBench shows below:
#include <iostream>
template<int ROWS, int COLS, int T>
void createColorBar(hls::Mat<ROWS, COLS, T> &imgColorbar)
hls::Scalar<HLS_MAT_CN(T), HLS_TNAME(T)> pixel;
int wBar;
int rows = imgColorbar.rows;
int cols = imgColorbar.cols;
for(int row=0;row<rows;row++)
#pragma HLS loop_flatten off
wBar = cols>>3;
for(int col=0;col<cols;col++)
#pragma HLS pipeline
int index = ((col)/wBar)&0x7;
switch(index)
case 0:
pixel.val[0] = 0x111;
pixel.val[1] = 0x111;
// pixel.val[2] = 0xff; //white
break;
case 1:
pixel.val[0] = 0x222;
pixel.val[1] = 0x222;
// pixel.val[2] = 0xff; //yellow
break;
case 2:
pixel.val[0] = 0x333;
pixel.val[1] = 0x000;
// pixel.val[2] = 0x00; //cyan
break;
case 3:
pixel.val[1] = 0xfff;
// pixel.val[2] = 0x00; //green
break;
case 4:
pixel.val[0] = 0x444;
pixel.val[1] = 0x444;
// pixel.val[2] = 0xff; //magenta
break;
case 5:
pixel.val[0] = 0x555;
pixel.val[1] = 0x555;
// pixel.val[2] = 0xff; //red
break;
case 6:
pixel.val[0] = 0x666;
pixel.val[1] = 0x666;
// pixel.val[2] = 0x00; //blue
break;
default:
pixel.val[0] = 0x777;
pixel.val[1] = 0x777;
// pixel.val[2] = 0x00; //black
break;
imgColorbar << pixel;
int main()
axi_stream_t RawIn;
axi_stream_t RawOut;
hls::Mat<IN_IMG_MAX_ROWS, IN_IMG_MAX_COLS, HLS_12UC2> imgColorbar(IN_IMG_MAX_ROWS, IN_IMG_MAX_COLS);
hls::Mat<OUT_IMG_MAX_ROWS, OUT_IMG_MAX_COLS, HLS_12UC2> outIMG(OUT_IMG_MAX_ROWS, OUT_IMG_MAX_COLS);
#pragma HLS dataflow
createColorBar(imgColorbar);
hls::Mat2AXIvideo(imgColorbar, RawIn);
hlsCrop(RawIn, RawOut);
hls::AXIvideo2Mat(RawOut, outIMG);
return 0;
and the modified design file is:
#include <iostream>
int rowIdx, colIdx;
pix_t inPix;
pix_t outPix;
int testOutImgPixCnt = 0;
// pix_t inPix;
// while(RawIn.empty()) {
if( ((IN_IMG_MAX_COLS -1) == colIdx) && ((IN_IMG_MAX_ROWS -1) == rowIdx) ) {
cout<<"the last pixel"<<endl;
rowIdx = 0;
colIdx = 0;
if(1 == inPix.last) {
colIdx = (IN_IMG_MAX_COLS -1);
// pix_t outPix;
testOutImgPixCnt ++;
if(testOutImgPixCnt >= (OUT_IMG_MAX_COLS * OUT_IMG_MAX_ROWS)) {
cout<<"test outImgPIxCnt"<<testOutImgPixCnt<<endl;
return;
and still two warning(but not keep printing),
WARNING: Hls::stream 'hls::stream<ap_uint<12> >.4' contains leftover data, which may result in RTL simulation hanging.
WARNING: Hls::stream 'hls::stream<ap_uint<12> >.3' contains leftover data, which may result in RTL simulation hanging.
I want to know, does it  mean that there are some warning about  the member  "ap_uint<U> user; ap_uint<1> last;"   ?    what should I do with the warning ?
template<int D,int U,int TI,int TD>
struct ap_axiu{
ap_uint<D> data;
ap_uint<(D+7)/8> keep;
ap_uint<(D+7)/8> strb;
ap_uint<U> user;
ap_uint<1> last;
ap_uint<TI> id;
ap_uint<TD> dest;
Observer kevin_pang
I use the code below to recover the stream when some errors occur, since it is a video stream.
rowIdx = 0;
colIdx = 0;
Hey @kevin_pang,
Nicholas Moellers
