linux drivers for my HLS ip
hi,
I am new to HLS. I build a simple HLS ip for test.
And this is followed demo BASE_TRD_ZC702.
(https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841616/Zynq+Base+TRD+2015.4)
In this demo , HLS module in device tree is described as :
	hls_1: hls@400d0000 {
		compatible = "xlnx,v-hls-sobel", "xlnx,v-hls";
		reg = <0x400d0000 0x20>, <0x400d0020 0xa4>;
		clocks = <&clkc 15>;
		ports {
			#address-cells = <1>;
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				xlnx,video-format = <XVIP_VF_YUV_422>;
				xlnx,video-width = <8>;
				hls_in: endpoint {
					remote-endpoint = <&vm2m_hls_out>;
			port@1 {
				reg = <1>;
				hls_out: endpoint {
					remote-endpoint = <&vm2m_hls_in>;
and its compatible driver is xilinx-hls.c (ref to attachment) , which locates at <linux-kernel>/drivers/media/platform/xilinx/
Then I setup a similar project with my own simple HLS ip, modified the register address in device tree,
the problem happened that when I start up board with BOOT.bin and image.ub,the log shows no HLS module found, that is I cannot find
dev_info(xhls->xvip.dev, "device %s found\n", xhls->compatible);
info printed in the startup log.
Also I noticed in some topics, it is suggested to use "generic-uio" to make a driver for HLS ip, but it seems not  in BASE_TRD_ZC702. as below link:
https://forums.xilinx.com/t5/Embedded-Linux/How-to-use-HLS-autogenerated-linux-drivers-in-Petalinux-recipe/m-p/877681#M27692
My question is what is the difference between those "generic-uio" and "xlnx,v-hls" drivers?
Is it ok to just use xilinx-hls.c driver in ZC702 demo for my own ip ?
How to implement drivers generated by vivado_hls in Linux ?
Sorry for my ignorance, but anyone can help me ?  thank you!
Re: linux drivers for my HLS ip
oh, I set the primary SD to ps7_sd_1 channel, and what I see is the log startup thru EMMC.
A foolish error!
Hello @mcggoal,
Thank you for posting that you found the solution to this. I don't think that I would call this mistake foolish, but I do think that logging the problem and your solution will help others from falling into that pitfall like you did, so I appreciate you doing that!
Thank you ,
Scott
