diptyajit
Automating VIO interaction using TCL in Vivado 2014.1
I am in the process of automating a 'live' debug on a Virtex 7 enabled board. I have already written a TCL script which takes the source files through the entire Vivado flow, generates  a bitstream and programs the board.
The idea is to have a script kick in at this point, which will control the VIO as per requirements. I can drive the OUTPUT of a VIO core, and the relevant command for this is commit_hw_vio(pg 114, UG 835). But I cannot find an equivalent TCL command to either -
(a) Explicitly READ from the VIO INPUT  or,
(b) Export the current INPUT value to a log of some sort.
I am only interested in the TCL interface since I would like to use VIvado in its - batch mode and feed it a script.
Tags (3)
vemulad
I think you can use below command to read input probe value.
get_property INPUT_VALUE [get_hw_probes BUTTON_IBUF]
where BUTTON_IBUF is the input probe of VIO core.
Refer to page-74 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug908-vivado-programming-debugging.pdf
Deepika.
Deepika.
vemulad
Deepika.
Deepika.
diptyajit
Addition
I have also found the csevio TCL commands thanks to this post
http://forums.xilinx.com/t5/Design-Tools-Others/How-to-drive-pre-assigned-input-via-VIO/td-p/459418
 but since the hardware debug section is integrated in Vivado, will the old  UG029 (v14.3 Oct 2012) manual intended for the Chipscope tool also hold true for Vivado 2014.1 ?
Similar questions and solutions are available here
http://forums.xilinx.com/t5/Design-Tools-Others/ChipScope-Engine-Tcl-interface/td-p/59658
But the date of the thread (2010) leads me to question if there is something new available that I am not aware of ?
diptyajit
Thanks Deepika ! That is the easiest way
