Voyager
Voyager
How to run Disk Label test from tcl?
Windows OS, I run into path length limit issue started using subst.
But every rerun of my script fails at this command because path replacement if alreay used (SUBSTed).
I had to run "exec subst V: /d" to remove it.
I'm wonder how to create a .tcl script to test if a label is already exist, so to prompt to remove before proceed. I can do this in .bat by using exist.
Please comment,
Re: How to run Disk Label test from tcl?
Hi, @legendbb ,
Hope the below example can be helpful:
set t "C:"
if { [file exist $t ] } {
puts "exist"
} else {
puts "Not exist"
Hi, @legendbb ,
set t "C:"
puts "exist"
} else {
puts "Not exist"
Voyager
Voyager
Great thanks,
