tnjames
How to test whether Vivado is running in batch or project mode using TCL?
We use Vivado in both project or batch modes and in both modes use TCL scripts to automate the process of adding design files and/or running through the build process.  I have a small number of scripts that define reusable procedures and typically a separate script for each library to add all the design files.  In some circumstances, eg, when adding IP cores, I want the behaviour when running in batch mode to be different to when running in project mode.  In principal this seems to be something that should be very straightforward, eg, if { [get_vivado_mode] eq "project" } { do_this} else {do_that } however I cannot find any documented method of determining the current vivado operating mode from within a TCL script/procedure.  Surely this is possible?  I had thought of trying to check whether current_project succeeds or fails however even in batch mode there are several operations that create a project, eg, calling set_part or synth_ip, so this approach isn't reliable.  Any pointers/suggestions welcome.
Thanks in advance.
Tim
amaccre
Hi @tnjames ,
$rdi::mode should return one of following depending on how Vivado was started.
gui
batch
tcl
You can also include it in a custom proc to make it more readable:
proc launch_mode {} {
puts $rdi::mode
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
amaccre
Hi @tnjames ,
gui
batch
tcl
puts $rdi::mode
Best Regards
Aidan
