pram
Packing an IP with AXI master interface
I have packaged the IP with AXI master interface. When i am packing , I go the address and memory and create a address space. How can i create below requirements in vivado ?
1. Package AXI Master inteface which can address a slave of 1 GB using TCL command?
I only see below options :
ipx::add_address_space -help
Description:
Add a new address space to a component.
Syntax:
ipx::add_address_space [-quiet] [-verbose] <name> <component>
Usage:
Name Description
[-quiet] Ignore command errors
[-verbose] Suspend message limits during command execution
<name> Name to initialize the newly added element
<component> Component object
Categories:
2. When i double click and change the range to larger number in GUI and then package the component.xml gets generated.
I like this RANGE come as 1 GB when i instantiate but i how can i package a AXI interface which configures the RANGE, SLAVE address etc using TCL commands?
