Post bitstream TCL script cannot find BIT file
I wrote a TCL script to convert a BIT file to a BIN file in SelectMAP format.
The script works great when I run it manually from the Vivado TCL console after write_bitstream is complete.
The same script fails when used as tcl.post in the write_bitstream process.The error given was that the BIT file could be found (but it was in fact generated in write_bitstream).
The TCL script is
set DIR [get_property DIRECTORY [current_project] ]
cd $DIR
write_cfgmem -format bin -size 64 -interface SMAPx32 -loadbit {up 0x00000000 "./project_1.runs/impl_1/FPGA_TOP.bit" } -force -disablebitswap -file ./project_1.runs/impl_1/FPGA_TOP.bin
Do you see a way to change this script so that it will find the BIT file when I run it both manually and also as a tcl.post to write_bitstream?
Thanks!
John
driesd
Hi John
the problem is that all Vivado runs are actually run out of the context of the Vivado project.
So, what you run in the Tcl console is not the same as in the context of the run. For example "current_project" does not exist in your "write bitstream" run.
However, in this case, you actually don't need it. The "write bitstream" run is in fact run in the impl_1 folder already, so your Tcl script is simply:
write_cfgmem -format bin -size 64 -interface SMAPx32 -loadbit {up 0x00000000 "FPGA_TOP.bit" } -force -disablebitswap -file FPGA_TOP.bin
Best regards
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
driesd
Hi John
Best regards
Dries
Thanks for the excellent tip. That completely resolved my issue.
driesd
Great to hear that!
