troelsfr
Programming FPGA from command line
Hi everyone,
How do I download a bitstream to the FPGA from the command line? It is fairly easy to do in Project mode, but in non-project mode I am somehow stuck with a bitstream and no clue of how to program my FPGA, so any hints would really be appreciated.
Troels
pulim
Here is a example script to do that, if you are looking to program the HW from command line.
# Connect to the Digilent Cable on localhost:3121
connect_hw_server -url localhost:3121
current_hw_target [get_hw_targets */xilinx_tcf/Digilent/12345]
open_hw_target
# Program and Refresh the XC7K325T Device
current_hw_device [lindex [get_hw_devices] 0]
refresh_hw_device -update_hw_probes false [lindex [get_hw_devices] 0]
set_property PROGRAM.FILE {C:/design.bit} [lindex [get_hw_devices] 0]
set_property PROBES.FILE {C:/design.ltx} [lindex [get_hw_devices] 0]
program_hw_devices [lindex [get_hw_devices] 0]
refresh_hw_device [lindex [get_hw_devices] 0]
Please refer to the document refered by others for more info.
troelsfr
Please note that I am using Vivado and not ISE.
vemulad
Open Vivado and Open Hardware manager from Flow --> Open hardware Manager.
Now connect to the board and load the bit file generated in non-project mode.
In case if you are looking for command line method to dump the bit file on board refer to page-83 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug908-vivado-programming-debugging.pdf
Deepika.
Deepika.
vuppala
Hello
Check this user guide: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug908-vivado-programming-debugging.pdf
It will help you with different switches and commands.
Vinay
ashishd
In non-project mode, you need to take special care about some commands. You need to specify them explicitly. For an example, in project mode the ILA probe file is automatically created during the implementation process. But in non-project mode you need to create it separately with below command
write_debug_probes filename.ltx
These and such differences you can figure out by going through UG pointed by Vinay and Deepika.
Ashish
pulim
open_hw_target
aher
hi,
you can once program the fpga using project mode and generate all the tcl command in the tcl console.
make your own script and see if it is working.
for example first few commands are
open_hw
connect_hw_server
thank,
Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in left) to a post which you think is helpful and reply oriented.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
troelsfr
Thanks for all of your answers - this is very helpful.
sachiniisc
How to run the tcl commands from command line?
I tried putting commands in a file and tried "xsim <filename>" which says simulation snapshot missing from command line.
I have a bitfile which needs to be burned. I don't want to load any project.
muzaffer
@sachiniisc
please don't revive 2 year old threads. Create a new one.
As to your question, xsim is for simulation. Programming the bit file is an entirely different process which is actually described in the current thread. The only piece of info missing is that the command you need to run the scripts shown is "xmd" not "xsim"
jyri_artec
Command line Vivado script for programming FPGA, Impact.exe replacement. Save to program_fpga.tcl.
Programs first fpga device connected to local machine hw server. Both bin and bit files can be used.
Run in Windows > vivado  -mode tcl -nolog -nojournal -source path\to\program_fpga.tcl -tclargs path\to\bitfile
Run in Linux       $ vivado  -mode tcl -nolog -nojournal -source path/to/program_fpga.tcl -tclargs path/to/bitfile
set bitfile [lindex $argv 0]
if { [file exists $bitfile] != 1 } {
    puts "No bitfile $bitfile"
    quit
} else {
    puts "Using bitfile $bitfile"
load_features labtools
open_hw
connect_hw_server -url TCP:localhost:3121
set targu [get_hw_targets *]
current_hw_target $targu
open_hw_target
set first_hw_device [lindex [get_hw_devices] 0]
current_hw_device $first_hw_device
set_property PROGRAM.FILE $bitfile $first_hw_device
# if ila included: set_property PROBES.FILE {C:/design.ltx} $first_hw_device
program_hw_devices $first_hw_device
# in case of "ERROR: [Labtools 27-3165] End of startup status: LOW"
# check that bitstream file is for target FPGA
# if ila included: refresh_hw_device $first_hw_device
quit
