hbl
Retrive IP version/revision numbers using Tcl
Is there a way to retrieve an IP/bd version and revision numbers using Tcl (e.g. [get_property <version/revision> $IP]
amaccre
Hi @hbl ,
Try the following for the revision version:
get_property CORE_REVISION [get_ips xxIP_NAMExx]
e.g.
get_property CORE_REVISION [get_ips Base_Zynq_MPSoC_axi_bram_ctrl_0_0]
2
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
hongh
Please try the below command:
Ex: %get_property IPDEF [get_ips XX]
hbl
Thanks for the reply. This only returns the version number (similar to VLNV) but not the revision number.
hongh
You have to catch the information from the generated file of the command "report_ip_status -file XX"
hbl
I guess no easy way to get the revision number! Would it be possible to get the ip_report_status source code to see how it retrieves the Rev #?
amaccre
Hi @hbl ,
e.g.
2
Best Regards
Aidan
hbl
Thanks Aidan, it worked.
In case someone else is looking for same info "report_property [get_ips <IP name>]" will list all properties attached to the IP.
