04-21-2017 02:27 AM
I want to create the example project with HDMI Transmitter ADV7511 and AC701 board from
https://github.com/analogdevicesinc/hdl/tree/master/projects/adv7511/ac701.
I run the project TCL file with source system_project.tcl. However, I get the error
ERROR: This project requires Vivado 2015.4.2.
while executing
"adi_project_create adv7511_ac701"
(file "system_project.tcl" line 6)
My Vivado version is 2016.2. Is Vivado not downward compatible?
Thanks in advance!
04-21-2017 04:14 AM
Hi rb@ ,
There is at least a couple of options to proceed:
1. Install Vivado 2015.4
2. Change REQUIRED_VIVADO_VERSION to 2016.2 in adi_project.tcl file (link), then try to compile and decide what to do next depending on the outcome. It might give an error, for example, because some IP Cores this project uses require exact 2015.4 version. Or it might just compile and work fine.
04-21-2017 04:14 AM
Hi rb@ ,
