lematthias
Substitute variable in tcl within apply_bd_automation command
I am trying to run apply_bd_automation with variables within the config list. Unfortunately I can't find the right syntax and Vivado throws "Invalid configuration value" errors.
This is the working command:
apply_bd_automation -rule xilinx.com:bd_rule:xdma -config { accel {1} auto_level {IP Level} axi_clk {Maximum Data Width} axi_intf {AXI Memory Mapped} bar_size {1 (Megabytes)} bypass_size {Disable} c2h {1} cache_size {32k} h2c {1} lane_width {X16} link_speed {8.0 GT/s (PCIe Gen 3)}} [get_bd_cells xdma_0]
Now let's say I wanted to use a variable for c2h:
set num 2
What do I have to replace "c2h {1}" with, in order to use the value stored in $num ?
I have tried many different variants. Here the complete error message when using "c2h {$num}":
apply_bd_automation -rule xilinx.com:bd_rule:xdma -config { accel {1} auto_level {IP Level} axi_clk {Maximum Data Width} axi_intf {AXI Memory Mapped} bar_size {1 (Megabytes)} bypass_size {Disable} c2h {$num} cache_size {32k} h2c {1} lane_width {X16} link_speed {8.0 GT/s (PCIe Gen 3)}} [get_bd_cells xdma_0]
ERROR: [XDMA-105] Invalid configuration value "$num" for "c2h".
ERROR: [Common 17-39] 'send_msg_id' failed due to earlier errors.
ERROR: [#UNDEF] Error found in procedure apply_rule.
INFO: [BD 5-145] Automation rule xilinx.com:bd_rule:xdma was not applied to object xdma_0
INFO: [Common 17-17] undo 'apply_bd_automation -rule xilinx.com:bd_rule:xdma -config { accel {1} auto_level {IP Level} axi_clk {Maximum Data Width} axi_intf {AXI Memory Mapped} bar_size {1 (Megabytes)} bypass_size {Disable} c2h {$num} cache_size {32k} h2c {1} lane_width {X16} link_speed {8.0 GT/s (PCIe Gen 3)}} [get_bd_cells xdma_0]'
ERROR: [Common 17-39] 'apply_bd_automation' failed due to earlier errors.
If necessary I can post a minimal example but basically creating an empty block design and running "create_bd_cell -type ip -vlnv xilinx.com:ip:xdma:4.1 xdma_0" and then the command from above should be enough to recreate the error.
Thank you very much in advance!
