Write TCL and recreate BD 2018.2
I have a project with top level VHDL file, and a lower level BD module which then uses the generated wrapper to instantiate it.
I have tried using Project->Write TCL to generate a script that I can use with SVN to create the project, but have found that when using the Recreate Block Designs it first of all tries to add in the wrapper file before it has even created the BD, which of course won't work, as the wrapper file is generated I don't really want to have to add it into SVN.
So what do I need to do to the TCL script to create the wrapper and have it added to the sources fileset?
Re: Write TCL and recreate BD 2018.2
@arnelln,
You can use make_wrapper TCL command to create a wrapper file for your BD design.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug835-vivado-tcl-commands.pdf#page=1032
After using make_wrapper file, you need to use add_files command to add the new generated wrapper file to your sources.
Example:
make_wrapper -files [get_files C:/Webcases/project_13/project_13.srcs/sources_1/bd/design_1/design_1.bd] -top
add_files -norecurse C:/Webcases/project_13/project_13.srcs/sources_1/bd/design_1/hdl/design_1_wrapper.v
--Syed
@arnelln,
Example:
--Syed
@syedz
Thanks for the response, it works.
