xilinx-zhaosheng
cannot locate target loader
When vivado is used to open the project, the Windowns7 report cannot locate the target loader.
vijayak
Hi @xilinx-zhaosheng
Which command are you using?
Thanks,Vijay
prathikm
 Hi @xilinx-zhaosheng,
Are you opening the tool and then using Open Project> .xpr?
You can check if registry is set to open the tool:
Open Windows and search for regedit.exe (Registery Editor).
Go to HKEY_CURRENT_USER and search for Vivado.Project.1 (Ctrl+F, F3 for next) and check the parameter for 201x.x. Then try to open the .xpr.
Thanks & Regards,
Prathik
Helpful answer -> Give Kudos
udaykumarurimi
I was facing same issue when I installed 2016.4. Though I uninstalled previous installation and installed 2016.4 som of the registry entries are pointing to the old installation.
I uninstalled 2016.4, cleaned the registry and re installed 2016.4
The issue is now resolved.
Amazing_z
1594290195.jpeg  My registry information is like this"Vivado.Project.1", how should I deal with it?
