could vivado tcl support parameters by command?
hi, I want to pass some args when excute my tcl in vivado, but seems it failed, any one could help to have a look?
source run.tcl try_parms
ERROR: [Common 17-165] Too many positional options when parsing 'try_parms', please type 'source -help' for usage info.
Re: could vivado tcl support parameters by command?
Hi @jeffson,
Please have a look at following forum thread solution:-
tcl-command-line-arguments
Chinmay
Hi @jeffson ,
Please go through the below link, might be helpful:
https://www.xilinx.com/support/answers/46668.html
Raj.
Hi @jeffson,
Chinmay
