how can I run a shell script in a TCL file in Windows.
in Windows
exec c:/projects/test/script.sh
does not work even though when I double click, the sh works. (sh includes mkdir and echo commands)
Re: how can I run a shell script in a TCL file in Windows.
Hi @999068709169 ,
In your .sh file pass both the in-built command with "exec cmd /c". For example:-
exec cmd /c mkdir new_dir6
exec cmd /c (echo Hello world)
and in the tcl console, simply source the .sh file without adding exec (ex: source new_script.sh). This should work. (refer to AR#59520)
Chinmay
a shell script is for linux.
You probably want a windows version of bash : http://win-bash.sourceforge.net/
Otherwise I suspect the script was written for a linux environment.
Hi @999068709169 ,
Chinmay
