Voyager
Voyager
read_xdc -unmanaged ?
HI Friends,
How to use the " read_xdc -unmanaged " command option for vivado ?
1) what is the use of it ?
pls explain with one example.
NOTE: any help or suggestions are highly appreciated.
Thank You
S Sampath
-Sampath
Re: read_xdc -unmanaged ?
Hi @ssampath,
The unmanaged constraints are mainly used to have controlling statements and loops to be used in constraint file. Please check the below thread which has the explanation regrading managed and unmanaged constraints.
https://forums.xilinx.com/t5/Vivado-TCL-Community/Using-IF-in-XDC-Files/td-p/560897
Hi, @ssampath ,
Have you read the below content in UG903?
Voyager
Voyager
After reading this only i got that doubt.
Can you pls explain more clearly , where we will use and how ?
Thank You
S Sampath
-Sampath
Hi, @ssampath ,
In short, with the -unmanaged option, you can use any common Tcl command which can not be used in the ordinary XDC file.
Voyager
Voyager
Hi @hongh,
Thank You,
But what is the use of the usage of other(non-xdc) tcl commands in xdc .
I want to know the main intention for adding this option ?
Can you pls provide one small example ?
Thank You
S Sampath
-Sampath
Hi, @ssampath ,
Maybe you can use "for loop" statemnet to check the existing netlist after certain impl stage and create new constriants in the design to improve timing in the sebsequent stage.
Here, "for loop" statemnet cannot be used in ordinary XDC file.
Hi @ssampath,
