save spreadsheet from report_utilization command in a format other than xlsx or read xlsx from tcl?
Hi, I want to extract some numbers from synthesis report in tcl. For instance, if the generated netlist uses 1000 CLB LUTs, I want to do something like
set clbUsage 1000
from tcl file.
Such info seems to be found with report_utilization command and can be exported to xlsx file using -spreadsheet_file and -spreadsheet_table flags together. At this point, I am running python script to read xlsx file and output in tcl list format so that tcl file can do something like set clbUsage 1000.
I think this is definitely not a clean way to achieve this... can I save report_utilization spreadsheet file in format other than xlsx like txt?
Re: save spreadsheet from report_utilization command in a format other than xlsx or read xlsx from tcl?
Hi @moon5756
Please try with the command i mentioned above (report_utilization -file <file_path>util.txt. I tried it at my end, and i got proper output in the text file unlike you got (broken).
See the attached file.
Hope this helps.
Rohit
Rohit
Hi @moon5756
You can use below command:
report_utilization -file <file_path>utl.txt
file_path is the path to the text file.
Hope this helps.
Rohit
Rohit
@thakurr
Doesn't it break though? I saved it as txt file and open it up with text editor and it seems to be broken..
I attached txt file that's generated from command
report_utilization -name utilization_1 -spreadsheet_file util_table.txt -spreadsheet_table "Hierarchy"
Hi @moon5756,
Changed .txt to .xls
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
Hi @moon5756
Hope this helps.
Rohit
Rohit
@thakurr
 @prathikm
Thanks for the reply,
so what I want to save is -spreadsheet_file but it seems like it's only available in GUI mode.(a file saved with -spreadsheet_file is a good form to be parsed) So in non GUI mode, do I need to save txt file with -file flag and parse to get CLB usage? This is doable, but doesn't seem like a clean solution. As I stated above, all I want to do is something like
set clbUse [some value]
