tcl command to get all cells outside pblocks
I have a design in vivado 2018.1. I have 3 pblocks say A, B and C.
After opening implemented design, I want to get list of all cells outside of pblocks A , B and C.
What is the tcl command for this?
Also is it possible to get only specific type of cells like FF, LUT, CARRY8 etc(which are outside pblocks).
Anyone please help.
Re: tcl command to get all cells outside pblocks
Hi @soccerchamp ,
Yes PBLOCK is a property.
So  if you want to try different TCL syntax to specifically achieve wht you want, i will suggest you to open the device view and do control +F
a Find window will open and you can try out:
Hope that helps.
Raj
Hi @soccerchamp ,
I am not sure on for finding specific cells, but for cells you can try to use below command:
show_objects -name find_1 [get_cells -hierarchical -filter { PBLOCK !~ "*" } ]
Raj
@rshekhaw
Thanks. It will surely help.
In the command , If I want to specificy the pblock names , how should it look like?
show_objects -name find_1 [get_cells -hierarchical -filter { PBLOCK !~ "A B C" } ]
is it correct?
Hi, @soccerchamp ,
It looks ok for the command. To get the specific cells, you can add the below content:
show_objects -name find_2 [get_cells -hierarchical -filter { PRIMITIVE_TYPE =~ CLB.LUT.*  &&  PBLOCK !~ "A B C" } ]
@hongh
Just for confirmation, I gave below command
show_objects -name find_1 [get_cells -hierarchical -filter { PBLOCK == "A" } ]
But there was no objects found.
Is PBLOCK is a property? Shouldn't we give properties in filer list?
Hi @soccerchamp ,
Hope that helps.
Raj
