Voyager
Voyager
unmanaged tcl script for constraint set ?
HI Friends,
In UG903 v2019.1 : page 7,
mentioned that read_xdc -unmanaged command. Can you please explain below statement more clearly and with small example if possible.
Generate the constraints with an unmanaged Tcl script.      <-----  How ?
To execute the Tcl script, do one of the following:
° Run the source command.
° Use the read_xdc -unmanaged command.          <-----------  This statement is  not clear
° Add the Tcl script to one of your project constraints sets.   <--------  How to add tcl script to constraint set?
Any help or suggestion is highly appreciated.
-Sam
-Sampath
Re: unmanaged tcl script for constraint set ?
Hi, @ssampath ,
TCL script means it's unmanaged. You just need to save the constraint into tcl script file (XX.tcl)
Ex: source ./XX.tcl
Add the file with the below command in TCL CONSOLE:
read_xdc -unmanaged ./t2.xdc
Add the tcl script into project constraints sets just like adding xdc and you can refer to the attached pic
Hi, @ssampath ,
Ex: source ./XX.tcl
Voyager
Voyager
Thank you  so much @hongh  foyour patience.
anyway we are using xdc file then what is the need to use xdc constraints inside tcl script and sourcing it and adding it to again constraints set ?
Are there any specific cases which are necessary required tcl script for xdc ?
-Sam
-Sampath
Hi, @ssampath ,
Only small parts of the tcl commands are supported in the XDC files.
If you intend to use the tcl commands which is unsuported in XDC, you have to use an unmanaged XDC/TCL.
Voyager
Voyager
Thank You @hongh ,
I understood, Can you please provide small example so that it's more clear to me or even any reference also fine.
-Sam
-Sampath
Historian
Historian
I think you may be confusing a number of concepts...
A given constraint is only specified once. However, there are multiple different ways of bringing that constraint into your design, depending on a number of things.
The first thing is that there are two separate modes of Vivado, project mode and non-project mode. The way constraints are brought in are different in the two modes.
In non-project mode, constraint files are read in using either
  • read_xdc <filename>
    • This is a managed XDC file
  • read_xdc -unmanaged <filename>
    • This is an unmanaged constraint file
  • source <filename of file that contains constraints>
    • This is also an unmanaged constraint file
In project mode, a constraint file is added to a constraint set. This is done
  • Using the GUI "Add Sources -> Add or create constraints"
    • If the suffix of the file is .xdc then this is a managed constraint file
    • If the suffix of the file is .tcl then this is an unmanaged constraint file
  • add_files -fileset constrs_1 <filename> or import_files -fileset constrs_1 <filename>
There are advantages and disadvantages to using managed vs. unmanaged constraints file
  • A managed constraint file allows the constraints to be "managed"
    • Advantatges
      • The constraints will show up in the Constraints window of the GUI
      • The constraints wizard will be aware of them
      • The constraints will be written out in an checkpoint written with write_checkpoint
      • The constraints will be used when the design is encapsulated as an IP
      • (and a bunch of other places)
    • Disadvantages
      • A managed constraint file is only allowed to use a limited subset of the Tcl language
        • Noteably, if, while, for, functions, and other "advanced" Tcl constructs are not allowed in managed XDC files
  • Unmanaged constraint file
    • Advantage
      • Can use the entire Tcl syntax
    • Disadvantage
      • The constraints aren't managed - they are basically invisible to all the things I listed above. They will still affect the design as intended (i.e. they are still constraints on the design), but they will not show up in all those "helper" processes I listed above
In general, you should stay away from unmanaged constraints. There are lots of places that it is assumed that all constraints are managed, and its hard for me to give you a list of cases where it is OK and not OK to use unmanaged constraint files. Furthermore, most of the time that people want to use unmanaged constraints (i.e. to use a syntax that is not allowed in managed constraint files) there is usually a mechanism of accomplishing the same goal using constraints that use only XDC compliant syntax.
Avrum
