Voyager
Voyager
vivado: export ip tcl generation script
Is it possible to export a tcl script that would help repackaging an IP in batch mode?
--Sebastien
Re: vivado: export ip tcl generation script
@sebo
If you are looking for a command similar to write_bd_tcl which can recreate the BD then I don't think there is such command which can do for repackaging the IP.
When packaging IP from GUI, You can copy the commands from TCL console and paste it in the TCL script.
--Syed
@sebo
--Syed
Voyager
Voyager
Too bad...
This IP is already created so I didn't want to go through the entire creation process again. It'd be a cool feature.
--Sebastien
