09-16-2019 07:22 AM
This is a very basic question that I can't find an answer to. I have vivado installed on windows and want to run it in batch mode, but when running the command
vivado -mode batch -source ../scripts/run_vivado.tcl
vivado is not recognised as an internal or external command.
I've tried adding the xilinx folder to my path, but that didn't seem to work.
Any suggestions?
09-16-2019 07:24 AM
You need to use the Xilinx vivado dos window , not the standard windows dos.
09-16-2019 07:34 AM
ah, so if i want to run vivado from another batch file, is this not possible?
09-16-2019 07:38 AM
09-16-2019 07:39 AM
you can call vivaod fomr any TCL file,
provided the orriginal was starter in the Vivado TCL command window
09-16-2019 08:13 AM
Hi, @ben_allen_arm ,
In the command line, please set the Vivado environment first.
Run settings64.bat under Vivado installation dir:
Ex:
C:\Xilinx\Vivado\2018.3\settings64.bat
