write_project_tcl IP version issue
Hi everybody,
I'm using Vivado 2014.4 on a Windows 7 64-bit machine and I'm trying to use write_project_tcl command to archive my project. I'm working in project-mode, so I export my build.tcl build file with:
File->Write Project Tcl
Then I put my build.tcl and all my "source_1" directory somewhere in my hard drive. I also edit the build.tcl file to suite the new location I chose. I changed:
- the "origin_dir",
- the "orig_proj_dir,
- the set_property "ip_repo_paths".
The modified file is attached.
When I try to rebuild my project sourcing build.tcl, everything seems to work fine. Block design and design wrapper files are correctly loaded. Xilinx proprietary IP are also correct but my own IP are not (the ones in the "ip_repo_paths"). If I run a report_ip_status they all result as "unsupported parts".
I noticed the source file list (# Set 'sources_1' fileset object) contains only .bd and .upgrade_log files. No .vhd or .v file are in the list.
Any suggestion to correctly rebuild the project?
Leoanrdo
Re: write_project_tcl IP version issue
The problem with my own IPs was the board device and the target language were not automatically recognized in the new-built project. Once correctly set  in the General Settings tab all my IPs got unlocked.
Thank you,
Leonardo
Hi Leonardo,
Please see if the below AR applies to your issue:
http://www.xilinx.com/support/answers/59239.html
Also, do check if the tool is providing any warnings while executing write_project_tcl command.
Tushar.
@leonardo_guidi How did you generate write_project_tcl? did you used -all_properties attribute? If not try it.
Regarding your custom IP, can you check the part of your project and IPs part
-Pratham
I checked the answer record 59239. The issue #2 seems to be the same as mine, but the solution given resolves only #1.
Ok, yes I get some warnings:
write_project_tcl {D:/lavoro/lavoro_marco/vivado/build.tcl}
WARNING: [filemgmt 56-28] Property 'runtime' is deprecated. If running in batch mode, please update your script and use 'xsim.simulate.runtime' instead.
WARNING: [filemgmt 56-28] Property 'unit_under_test' is deprecated. If running in batch mode, please update your script and use 'xsim.simulate.uut' instead.
WARNING: [filemgmt 56-28] Property 'xelab.debug_level' is deprecated. If running in batch mode, please update your script and use 'xsim.elaborate.debug_level' instead.
WARNING: [filemgmt 56-28] Property 'xelab.load_glbl' is deprecated. If running in batch mode, please update your script and use 'xsim.elaborate.load_glbl' instead.
WARNING: [filemgmt 56-28] Property 'xelab.more_options' is deprecated. If running in batch mode, please update your script and use 'xsim.elaborate.xelab.more_options' instead.
INFO: [Common 17-14] Message 'filemgmt 56-28' appears 100 times and further instances of the messages will be disabled. Use the Tcl command set_msg_config to change the current settings.
INFO: [Vivado-projutils-8] Tcl script generated (D:/lavoro/lavoro_marco/vivado/build.tcl)
WARNING: [Vivado-projutils-10] Found source(s) that were local or imported into the project. If this project is being source then please ensure that the project source(s) are also part of this source controlled data. The list of these local source(s) can be found in the generated script under the header section.
Leonardo
Thank you,
Leonardo
Hi Leonardo,
It is good to know that your issue is resolved.
Please mark your post as 'Accept as Solution' so that it will help others facing similar issue.
Tushar.
