取消
显示结果
显示  仅  | 搜索替代
您的意思是:
661 次查看
注册日期: ‎06-25-2018
HLS 函数hls::Dilate无图像数据输出
使用HLS 的opencv函数hls::Dilate<hls::MORPH_ELLIPSE,1>(temp0_pre,temp1_pre,k5);综合RTL仿真,图像数据输出全为FF,
没有正常的像素数据输出。
代码如下:
1.hls代码
void hls_Dilate_8bit(AXI_STREAM_IN& input, AXI_STREAM_OUT& output, int rows, int cols) {
#pragma HLS RESOURCE variable=input core=AXI4Stream metadata="-bus_bundle INPUT_STREAM"
#pragma HLS RESOURCE variable=output core=AXI4Stream metadata="-bus_bundle OUTPUT_STREAM"
#pragma HLS INTERFACE ap_none port=cols
#pragma HLS INTERFACE ap_none port=rows
RGB_IMAGE img_0(rows, cols);
RGB_IMAGE img_1(rows, cols);
RGB_IMAGE img_2(rows, cols);
hls::Window<9,9,unsigned char> k4;
#pragma HLS DATAFLOW // must use data flow to stream the data
hls::AXIvideo2Mat(input, img_0); //read video stream by frames
hls::Dilate<hls::MORPH_ELLIPSE,2>(img_0,img_1,k4);
hls::Erode<hls::MORPH_ELLIPSE,2>(img_1,img_2,k4);
hls::Mat2AXIvideo(img_2, output); //write the frames to video stream
顶层代码
#include "top.h"
#include "opencv/cv.h"
#include "opencv/cxcore.h"
#include "opencv/highgui.h"
#include "hls_opencv.h"
int main (int argc, char** argv) {
    IplImage* src=cvLoadImage(INPUT_IMAGE,0);
    IplImage* dst = cvCreateImage(cvGetSize(src), src->depth, src->nChannels);
    AXI_STREAM_IN src_axi;
    AXI_STREAM_OUT dst_axi;
    IplImage2AXIvideo(src, src_axi); //将图像转为视频流结构
    hls_Dilate_8bit(src_axi, dst_axi, src->height, src->width);
    AXIvideo2IplImage(dst_axi, dst);
    cvSaveImage(OUTPUT_IMAGE, dst);
    cvReleaseImage(&src);
    cvReleaseImage(&dst);
toph代码
#ifndef _TOP_H_
#define _TOP_H_
#include"hls_video.h" //这里调用可以综合的视频库
// maximum image size
#define MAX_WIDTH 1280
#define MAX_HEIGHT 1024
// I/O Image Settings
#define INPUT_IMAGE "6.jpg"
#define OUTPUT_IMAGE "result_out.jpg"
#define OUTPUT_IMAGE_GOLDEN "result_golden.jpg"
// typedef video library core structures
typedef hls::stream<ap_axiu<8,1,1,1> > AXI_STREAM_IN;
typedef hls::stream<ap_axiu<8,1,1,1> > AXI_STREAM_OUT;
typedef hls::Mat<MAX_HEIGHT, MAX_WIDTH, HLS_8UC1> RGB_IMAGE;
typedef hls::Mat<MAX_HEIGHT, MAX_WIDTH, HLS_8UC1> GRAY_IMAGE;
// top level function for HW synthesis
void hls_Dilate_8bit(AXI_STREAM_IN& src_axi, AXI_STREAM_OUT& dst_axi, int rows, int cols);
#endif
3.综合仿真后RTL仿真结果(输入图片数据,但是输出全为ff)没有图像数据输出
4.下载到硬件显示也是白色的图片。
问题是在使用hls::Dilate<hls::MORPH_ELLIPSE,2>(img_0,img_1,k4);综合后RTL仿真没有图像数据输出
0 项奖励
0 回复数
