取消
显示结果
搜索替代
您的意思是:
Visitor yanjian
334 次查看
注册日期: ‎11-28-2018
VIVADO HLS编译错误
Starting C simulation ...
C:/Xilinx/Vivado_HLS/2016.3/bin/vivado_hls.bat D:/xiilx/milianke/array_test/array_test/solution1/csim.tcl
INFO: [HLS 200-10] Running 'C:/Xilinx/Vivado_HLS/2016.3/bin/unwrapped/win64.o/vivado_hls.exe'
INFO: [HLS 200-10] For user 'Administrator' on host 'win-20170406dtz' (Windows NT_amd64 version 6.1) on Tue Dec 11 20:59:17 +0800 2018
INFO: [HLS 200-10] In directory 'D:/xiilx/milianke/array_test'
INFO: [HLS 200-10] Opening project 'D:/xiilx/milianke/array_test/array_test'.
INFO: [HLS 200-10] Opening solution 'D:/xiilx/milianke/array_test/array_test/solution1'.
INFO: [SYN 201-201] Setting up clock 'default' with a period of 10ns.
INFO: [HLS 200-10] Setting target device to 'xc7z014sclg400-1'
INFO: [SIM 211-2] *************** CSIM start ***************
WARNING: [SIM 211-51] HLS only supports CLANG compiler in Linux.
INFO: [SIM 211-4] CSIM will launch GCC as the compiler.
Compiling ../../../../testbench.cpp in debug mode
Compiling ../../../../thin.cpp in debug mode
Generating csim.exe
In file included from C:/Xilinx/Vivado_HLS/2016.3/include/floating_point_v7_0_bitacc_cmodel.h:143:0,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls_half.h:40,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls/utils/x_hls_utils.h:37,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls/hls_axi_io.h:40,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls_video.h:48,
from ../../../../thinn.h:3,
from ../../../../testbench.cpp:1:
C:/Xilinx/Vivado_HLS/2016.3/include/gmp.h:62:0: warning: "__GMP_LIBGMP_DLL" redefined [enabled by default]
C:/Xilinx/Vivado_HLS/2016.3/include/floating_point_v7_0_bitacc_cmodel.h:135:0: note: this is the location of the previous definition
from ../../../../thin.cpp:2:
obj/thin.o:thin.cpp:(.data+0x20): multiple definition of `Rotate'
obj/testbench.o:testbench.cpp:(.data+0x20): first defined here
obj/thin.o:thin.cpp:(.data+0x68): multiple definition of `Transpose'
obj/testbench.o:testbench.cpp:(.data+0x68): first defined here
obj/thin.o:thin.cpp:(.data+0x80): multiple definition of `CamcameraMatrix'
obj/testbench.o:testbench.cpp:(.data+0x80): first defined here
collect2: ld returned 1 exit status
make: *** [csim.exe] Error 1
ERROR: [SIM 211-100] 'csim_design' failed: compilation error(s).
INFO: [SIM 211-3] *************** CSIM finish ***************
4
while executing
"source D:/xiilx/milianke/array_test/array_test/solution1/csim.tcl"
invoked from within
"hls::main D:/xiilx/milianke/array_test/array_test/solution1/csim.tcl"
("uplevel" body line 1)
invoked from within
"uplevel 1 hls::main {*}$args"
(procedure "hls_proc" line 5)
invoked from within
"hls_proc $argv"
Finished C simulation.
不知道是什么错误???完全找不到原因? 谢谢!!!
0 项奖励
1 条回复1
287 次查看
注册日期: ‎05-27-2018
回复: VIVADO HLS编译错误
Hi @yanjian,
     根据你的报错提示,有变量重定义的错误,方便把您的文件贴出来吗?
 谢谢,
Wen
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
