取消
显示结果
显示  仅  | 搜索替代
您的意思是:
yang_mingkai
2,518 次查看
注册日期: ‎12-06-2018
place_design error for solution
i'm a beginner
i just tried a exercise,but it failed.
 [Place 30-574] Poor placement for routing between an IO pin and BUFG. If this sub optimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .xdc file to demote this message to a WARNING. However, the use of this override is highly discouraged. These examples can be used directly in the .xdc file to override this clock rule.
< set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets clk_IBUF] >
clk_IBUF_inst (IBUF.O) is locked to IOB_X1Y163
and clk_IBUF_BUFG_inst (BUFG.I) is provisionally placed by clockplacer on BUFGCTRL_X0Y31
 I do this as it described
As follow
set_property -dict {PACKAGE_PIN E3 IOSTANDARD LVCMOS33} [get_ports clk]
set_property CLOCK_DEDICATED_ROUTE FALSE[get_nets clk_i]
create_clock -period 10.000 -name clk_i -waveform {0.000 5.000} -add [get_ports clk]
but it's of no use
what should i do?
0 项奖励
13 回复数
graces
2,510 次查看
注册日期: ‎07-17-2008
关于此错误信息,请参考以下Answer:
https://www.xilinx.com/support/answers/64452.html
一般是未放到时钟专用管脚,或者放到了时钟专用差分输入管脚的_N。
注意到你加的CLOCK_DEDICATED_ROUTE约束是应用在了get_nets clk_i,而非错误信息建议的clk_IBUF。请按照提示的约束进行修改,此属性需要设置在IBUF输出信号上。
0 项奖励
yang_mingkai
2,507 次查看
注册日期: ‎12-06-2018
你好
我改了
改成了 get nets clk_IBUF.但是问题没解决。
我编的程序是最简单的那种,是一个入门教程上的程序。我着实弄不懂这是为啥
0 项奖励
graces
2,485 次查看
注册日期: ‎07-17-2008
请问你用的是哪个Vivado版本?使用的例程能附上吗?
0 项奖励
yang_mingkai
2,475 次查看
注册日期: ‎12-06-2018
我用的vivado2018.2
xdc
set_property CLOCK_DEDICATED_ROUTE FALSE[get_nets clk_IBUF]
set_property -dict {PACKAGE_PIN H17 IOSTANDARD LVCMOS33} [get_ports led]
就这四个
然后design source
`timescale 1ns / 1ps
module exercise(
input clk,
output led
reg [24:0] count = 0;
assign led = count[24];
always @ (posedge(clk)) count <= count + 1;
endmodule
0 项奖励
yang_mingkai
2,474 次查看
注册日期: ‎12-06-2018
0 项奖励
graces
2,458 次查看
注册日期: ‎07-17-2008
按照你提供的链接创建工程,并未复现你的错误。
请确认你选择的是Digilent的那块板子?如按照链接所示,选择Zybo的话,clk管脚对应的位置应为L16。
0 项奖励
yang_mingkai
2,383 次查看
注册日期: ‎12-06-2018
我用的不是链接的那块板子
我用的a7 100T 那块板子  clk管脚应该是E3好像
但是我不太懂换了一块板子一个很简单的编程就会出现错误了吗
不应该这个程序对于所有板子都应该适用吗?最多就是管脚不同,然后xdc里面有些小小的差异吧
0 项奖励
graces
2,356 次查看
注册日期: ‎07-17-2008
不同的封装,时钟专用管脚对应的IO位置是不一样的,不兼容的两个器件不能直接沿用原来的IO约束。
0 项奖励
yang_mingkai
2,347 次查看
注册日期: ‎12-06-2018
这个我明白  所以我在A7 100T上 clk管脚是它的专用管脚 e3   led也是它的管脚
然后我source design 没变  ,constrains source 只是因为封装不同管脚,电压什么的不同了  其他都没变
这样也会引起不同板子就会有错误吗
0 项奖励
graces
2,340 次查看
注册日期: ‎07-17-2008
如果是同样的源文件,请告知你的具体器件封装以及更新后的XDC。对于专用的时钟管脚来说,不会出现以上错误。
0 项奖励
yang_mingkai
2,247 次查看
注册日期: ‎12-06-2018
抱歉这么久才回复
我的vivado版本2018.2    板子是A7 100T
我的xdc文件
就这四个
然后design source
module exercise(
input clk,
output led
endmodule
0 项奖励
graces
2,223 次查看
注册日期: ‎07-17-2008
A7 100T具体什么封装?
在工程的Package Pins Window中查看E3,是时钟专用输入管脚(SRCC/MRCC)吗?
0 项奖励
yang_mingkai
2,196 次查看
注册日期: ‎12-06-2018
您好,麻烦了
我查看了我觉得是的吧(不敢肯定),因为我看很多demo什么的都是E3管脚
我的文件压缩在附件里面了。麻烦您帮我看看
真的谢谢你了
0 项奖励
