取消
显示结果
搜索替代
您的意思是:
123 次查看
注册日期: ‎07-31-2020
vivado 2020.1 : [IP_Flow 19-3664] Warning
用的是vivado 2020.1版本,报出以下warning, 应该怎么消除?谢谢!
[IP_Flow 19-3664] IP 'uplink_30p72_lpf_xip' generated file not found 'c:/Users/86189/Documents/work/work_space/rru_c001/prj.srcs/sources_1/ip/uplink_30p72_lpf_xip/cmodel/uplink_30p72_lpf_xip.h'. Please regenerate to continue
[Common 17-576] 'use_project_ipc' is deprecated. This option is deprecated and no longer used.
0 项奖励
1 回复
56 次查看
注册日期: ‎11-05-2010
这用的是什么器件,什么IP?
0 项奖励
