取消
显示结果
搜索替代
您的意思是:
Observer yanjian
1,043 次查看
注册日期: ‎11-28-2018
vivado hls编译过程中C仿真没通过但是C综合通过了??????
Starting C simulation ...
C:/Xilinx/Vivado_HLS/2016.3/bin/vivado_hls.bat D:/xiilx/milianke/thinn/hlx_thin/hlx_thin/solution1/csim.tcl
INFO: [HLS 200-10] Running 'C:/Xilinx/Vivado_HLS/2016.3/bin/unwrapped/win64.o/vivado_hls.exe'
INFO: [HLS 200-10] For user 'Administrator' on host 'win-20170406dtz' (Windows NT_amd64 version 6.1) on Tue Jan 22 18:03:37 +0800 2019
INFO: [HLS 200-10] In directory 'D:/xiilx/milianke/thinn/hlx_thin'
INFO: [HLS 200-10] Opening project 'D:/xiilx/milianke/thinn/hlx_thin/hlx_thin'.
INFO: [HLS 200-10] Opening solution 'D:/xiilx/milianke/thinn/hlx_thin/hlx_thin/solution1'.
INFO: [SYN 201-201] Setting up clock 'default' with a period of 10ns.
INFO: [HLS 200-10] Setting target device to 'xq7a50tfg484-2i'
INFO: [SIM 211-2] *************** CSIM start ***************
WARNING: [SIM 211-51] HLS only supports CLANG compiler in Linux.
INFO: [SIM 211-4] CSIM will launch GCC as the compiler.
Compiling ../../../../testbench.cpp in debug mode
In file included from C:/Xilinx/Vivado_HLS/2016.3/include/floating_point_v7_0_bitacc_cmodel.h:143:0,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls_half.h:40,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls/utils/x_hls_utils.h:37,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls/hls_axi_io.h:40,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls_video.h:48,
from ../../../../thinn.h:3,
from ../../../../testbench.cpp:1:
C:/Xilinx/Vivado_HLS/2016.3/include/gmp.h:62:0: warning: "__GMP_LIBGMP_DLL" redefined [enabled by default]
C:/Xilinx/Vivado_HLS/2016.3/include/floating_point_v7_0_bitacc_cmodel.h:135:0: note: this is the location of the previous definition
In file included from C:/Xilinx/Vivado_HLS/2016.3/include/opencv2/core/core_c.h:47:0,
from C:/Xilinx/Vivado_HLS/2016.3/include/opencv2/opencv.hpp:46,
from C:/Xilinx/Vivado_HLS/2016.3/include/hls_opencv.h:47,
from ../../../../testbench.cpp:2:
C:/Xilinx/Vivado_HLS/2016.3/include/opencv2/core/types_c.h: In function 'int cvRound(double)':
C:/Xilinx/Vivado_HLS/2016.3/include/opencv2/core/types_c.h:324:28: error: call of overloaded 'lrint(double&)' is ambiguous
C:/Xilinx/Vivado_HLS/2016.3/include/opencv2/core/types_c.h:324:28: note: candidates are:
c:\xilinx\vivado_hls\2016.3\msys\bin\../lib/gcc/mingw32/4.6.2/../../../../include/math.h:686:21: note: long int lrint(double)
C:/Xilinx/Vivado_HLS/2016.3/include/hls_half.h:2597:15: note: long int detail::lrint(half)
C:/Xilinx/Vivado_HLS/2016.3/include/hls/hls_round.h:412:10: note: long int hls::lrint(double)
make: *** [obj/testbench.o] Error 1
这个编译问题是什么???
0 项奖励
4 条回复4
997 次查看
注册日期: ‎05-27-2018
回复: vivado hls编译过程中C仿真没通过但是C综合通过了??????
Hi @yanjian,
    从你给的部分log来看,没有显示综合已完成,可以贴出/附件给出相关代码吗?
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
Observer yanjian
983 次查看
注册日期: ‎11-28-2018
代码
void thinning(AXI_STREAM& src, Point_3f arry_out[MAX_WIDTH], int rows, int cols)
#pragma HLS INTERFACE axis port=src bundle=INPUT_STREAM
#pragma HLS INTERFACE s_axilite port=rows bundle=CONTROL_BUS offset=0x14
#pragma HLS INTERFACE s_axilite port=cols bundle=CONTROL_BUS offset=0x1C
#pragma HLS INTERFACE s_axilite port=return bundle=CONTROL_BUS
#pragma HLS INTERFACE ap_stable port=rows
#pragma HLS INTERFACE ap_stable port=cols
gray_IMAGE src0(rows,cols);
gray_IMAGE src1(rows,cols);
gray_IMAGE src2(rows,cols);
//static ap_fixed<18,4> distCoeffs[5] ={ 0.12394, -10.03379, -0.00295, 0.00988, 174.17315};
// gray_IMAGE dst(rows,cols);
#pragma HLS dataflow
hls::AXIvideo2Mat(src, src0);
assert(rows <= MAX_HEIGHT);
assert(cols <= MAX_WIDTH);
hls::Threshold(src0, src1, 240, 1, HLS_THRESH_BINARY);
hls::GaussianBlur<3,3>(src1, src2, 0,0);
int num=0;
int x;
int y;
int k1;
int num_point;
int nw;
int no;
int ne; // north (pAbove)
int we;
int me;
int ea;
int sw;
int so;
int se;
static int arry_imga[1236][1626];
static int dsst[1236][1626];
static int dsst1[1236][1626];
// uint_24 _buff[1920*1080];
static int arry_a[2009736];
//struct Point3f arry_imag[1626];
//ap_int<12> dst_array[1626][2];
//hls::bayer_8 video_data[1920][1080];
hls::Mat2Array<1626>(src2,arry_a);
thinning_label0:for(y=0;y<rows-1;y++)
for(x=0;x<cols-1;x++)
arry_imga[y][x]=arry_a[y*cols+x];
thinning_label1:do
thinning_label3:for(k1=0;k1<2;k1++){
//static ap_uint<1> dsst[1236][1626];
thinning_label4:for (y = 1; y <rows-1; y++) {
thinning_label5:for (x = 1; x < cols-1; x++) {
dsst[y][x]=arry_imga[y][x];
nw = arry_imga[y - 1][x - 1];
no = arry_imga[y - 1][x];
ne = arry_imga[y - 1][x + 1];
we = arry_imga[y][x - 1];
me = arry_imga[y][x];
ea = arry_imga[y][x + 1];
sw = arry_imga[y + 1][x - 1];
so = arry_imga[y + 1][x];
se = arry_imga[y + 1][x + 1];
int A = (no == 0 && ne == 1) + (ne == 0 && ea == 1) +
(ea == 0 && se == 1) + (se == 0 && so == 1) +
(so == 0 && sw == 1) + (sw == 0 && we == 1) +
(we == 0 && nw == 1) + (nw == 0 && no == 1);
int B = no + ne + ea + se + so + sw + we + nw;
int m1 = k1 == 0 ? (no * ea * so) : (no * ea * we);
int m2 = k1 == 0 ? (ea * so * we) : (no * so * we);
if (A == 1 && (B >= 2 && B <= 6) && m1 == 0 && m2 == 0)
dsst[y][x] = 1;
arry_imga[y][x] = arry_imga[y][x]&(~dsst[y][x]);
for (y = 0; y <rows-1; y++) {
for (x = 0; x < cols-1; x++) {
num_point = 0;
if(dsst[y][x]!=arry_imga[y][x]) num_point = num_point+1;
}while(num_point>0);
thinning_label2:for (y = 0; y <rows-1; y++) {
if(dsst1[y][x]>0)
arry_out[num].x=y;
arry_out[num].y=x;
num++;
仿真结果
INFO: [HLS 200-10] For user 'Administrator' on host 'win-20170406dtz' (Windows NT_amd64 version 6.1) on Thu Jan 24 08:55:19 +0800 2019
ERROR: [SIM 211-100] 'csim_design' failed: compilation error(s).
INFO: [SIM 211-3] *************** CSIM finish ***************
4
while executing
"source D:/xiilx/milianke/thinn/hlx_thin/hlx_thin/solution1/csim.tcl"
invoked from within
"hls::main D:/xiilx/milianke/thinn/hlx_thin/hlx_thin/solution1/csim.tcl"
("uplevel" body line 1)
invoked from within
"uplevel 1 hls::main {*}$args"
(procedure "hls_proc" line 5)
invoked from within
"hls_proc $argv"
Finished C simulation.
0 项奖励
955 次查看
注册日期: ‎05-27-2018
Hi @yanjian,
     代码不完整,缺少头文件,无法复现工程,types_c.h 里面的fuction的数据类型有问题。
0 项奖励
Observer yanjian
953 次查看
注册日期: ‎11-28-2018
头文件
thinn.h
#ifndef _THINN_H_
#define _THINN_H_
#include "hls_video.h"
//#include "hls_opencv.h"
#include<iostream>
#include<math.h>
#include<fstream>
#include"omp.h"
#include "ap_int.h"
//#include “ap_cint.h”
using namespace hls;
using namespace std;
#define MAX_WIDTH 1626
#define MAX_HEIGHT 1236
typedef hls::stream<ap_axiu<32,1,1,1> > AXI_STREAM;
typedef hls::Scalar<3, unsigned char> RGB_PIXEL;
typedef hls::Mat<MAX_HEIGHT, MAX_WIDTH, HLS_8UC1> gray_IMAGE;
typedef struct Point_type
int x;
int y;
} Point_3f;
//#include<opencv2/opencv.h>
#define INPUT_IMAGE "R_48.bmp"
void thinning(AXI_STREAM& src, Point_3f arry_out[MAX_WIDTH],int row,int col);
#endif
testbench.cpp
#include "thinn.h"
using namespace cv;
int main(int argc, char** argv)
IplImage* src=cvLoadImage(INPUT_IMAGE,0);
IplImage* dst = cvCreateImage(cvGetSize(src), src->depth, src->nChannels);
cvShowImage("hls_src", src);
Point_3f arry_out[MAX_WIDTH];
ofstream final("E://pic//test.txt");
//HLS视频库处理
AXI_STREAM src_axi;
IplImage2AXIvideo(src, src_axi);
thinning(src_axi,arry_out, src->height, src->width);
// AXIvideo2IplImage(dst_axi, dst);
// cvShowImage("hls_dst", dst);
//cvSaveImage(OUTPUT_IMAGE,dst);
// waitKey(0);
for(int i=0;i<MAX_WIDTH;i++)
if (final.is_open())
final<<arry_out[i].x<<","<<arry_out[i].y<<endl;
final.close();
waitKey(0);
return 0;
0 项奖励
