Visitor glabouski
Asynchronous option on ISE
I used to work on Vivado, but I am now on project using ISE, so I am looking for an equivalent syntax of the "set_clock_groups - asynchronous" option for UCF. As I have a huge number of asynchronous clocks (more than ten), I am trying to avoid using a lot of "FROM-TO", but did not see anything about making asynchronous clock constraints on Xilinx documentation.
Is there any tips to have that kind of constraint with a few number of lines in UCF ?
Re: Asynchronous option on ISE
UCF by default does not time between asynchronous clock groups, while in XDC, all clocks are considered related and timed unless otherwise constrained using
set_clock_groups
You have to time two different clock domains in case of ISE explicitly. all clock groups are asynchronous by default.
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
set_clock_groups
-Shreyas
@glabouski,
We do have a userguide which helps in migrating between ISE and Vivado. Please go through it.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug911-vivado-migration.pdf
--Syed
