mattsini1
Build Linux Boot image for Zedboard
Hi everyone, I'm trying to build the linux boot image but i'm having some problem to do that.
I've just read and tried to follow the xilinx guide but sincerely i think that it is not clear for first approach.
I've aso tried to follow the tutorial but when i try to make the u-boot i receive this error and I don't know what i have to do to continue.
Could someone describe clearly how to build a bootable Linux image step by step please?
Thanks a lot!
Mattia.
balkris
Upgrade the ARM toolchain to GCC 5:
sudo apt-add-repository "deb http://fr.archive.ubuntu.com/ubuntu/ wily main"
sudo apt-get update
sudo apt-get install g++-5-arm-linux-gnueabihf
sudo rm -f /usr/bin/arm-linux-gnueabihf-gcc /usr/bin/arm-linux-gnueabihf-g++
sudo ln -s /usr/bin/arm-linux-gnueabihf-gcc-5 /usr/bin/arm-linux-gnueabihf-gcc
sudo ln -s /usr/bin/arm-linux-gnueabihf-g++-5 /usr/bin/arm-linux-gnueabihf-g++
sudo apt-add-repository  --remove "deb http://fr.archive.ubuntu.com/ubuntu/ wily main"
You may be Missing Device Tree Compiler.
Try Install [In case of Ubuntu]
sudo apt-get install device-tree-compiler
Thanks and Regards
Balkrishan
mattsini1
Thanks for your reply, after install the dtc I have finally completed all the procedure but i'm having problem to build the image.
At the end of the tutorial that i followed he create the boot image with Xilinx SDK using the .elf file but he has an old version of SDK.
The 2016.4 version requires the UDF data (I have no idea what it is), however I tried to select the .elf file but it returns an error.
Can you explain me how I can build an image with SDK 2016.4 and wich file produced during the procedure i have to use?
Thanks a lot.
Mattia.
