piyushashtikar
Building linux for ML605?
    We are making a custom a board based on vertex7.
Presently we only have ML605 (vertex6) board for testing and learning.
    Our application needs us to boot basic linux on vertex7 Microblaze-FMCOMMS5 as given here:
https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/software/linux/microblaze?s[]=vc707
1:  Is this a petalinux distro or basic linux from source?
    Until our board arrives I want to learn porting linux on Microblaze.I am following this
http://www.lemays.org/blog/linuxforxilinxmicroblazeonml605.
2:    But all links are dead here. What should be my starting point?
"What is right process or document to start with"? Do I have to go for petalinux or basic linux from source?
balkris
you can find reference designs here
http://www.xilinx.com/products/boards/ml605/reference_designs_12.1_archive.htm
Thanks and Regards
Balkrishan
piyushashtikar
Thank you for quick reply.
I have already implemented microblaze on it.
I need "Working Document" for porting linux on ML605.
Piyush Ashtikar
balkris
not sure whether this doc can help you
http://www.xilinx.com/support/documentation/boards_and_kits/ug730.pdf
Thanks and Regards
Balkrishan
