rakeshm55
.COE file to initialize block ram
 i have a ROM intantiated using Core Gen. the ROM is implemented in BRAM..
its size is 120 bit width and depth of 256.
I want to initialize ROM values. I tried to generate .coe file using memory editor. But herein i am unable to provide the width parameter as 120 as it is limited to 16 bit width.
So in Memory editor I provied width as 16 and depth as 1920 to match the same no of memory locations (256X120), here i met with a validation error.
How can i initialize such a memory??
aher
how many entries have you made?
can you attach .coe file so that it can be varified?
thanks
shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
vsrunga
Instead of memory editor please follow the syntax and examples given in below link and have your own .coe file and recheck
http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/cgn_r_coe_file_syntax.htm
Hope it helps
Vanitha
yenigal
you should also make sure the Coe file generated matches your  ROM configuration parameters(width and depth). Validation error will happen if they don't match.
Satish
jigarmori
