Cannot run HW server from SDK
I'm trying to boot linux from the SDK that accompanies Vivado. In the walkthroug one of the first steps is to launch the XSDB terminal in the SDK then run the command "connect".
When I do this I recieve the error
"attempting to launch hw server
Failed to open a temporay file: file326f220
can't read "inifile": no such variable"
In the walkthrough the print out into the terminal should basically state that the HW server was started successfully. Can anyone give some help as to why the server won't start?
Tags (3)
I've found you can run it from the command line without the same issue. Simply navigate to the bat file hw_server.bat within the binary directory of your Vivado instance and run it.
