Observer nandish
Chipscope pro not detecting cabel
I am using Chipscope Pro analyzer on 64 bit Windows 7 machine. When I try to detect Digilent POlatform JTAG USB cabel it gives following error:
COMMAND: update_digilent_cable_list
INFO: Started ChipScope host (localhost:50001)
INFO: Successfully opened connection to server: localhost:50001 (localhost/127.0.0.1)
INFO: Digilent USB JTAG Cables connected:
    JtagSmt1/SN:210203337581
COMMAND: open_digilent_usb_cable DEVICE=SN:210203337581 FREQUENCY=6000000
INFO: Digilent Plugin: Opening device : "SN:210203337581".
INFO: Digilent Plugin: User Name: JtagSmt1
INFO: Digilent Plugin: Product Name: Digilent JTAG-SMT1
INFO: Digilent Plugin: Serial Number: 210203337581
INFO: Digilent Plugin: Product ID: 30800151
INFO: Digilent Plugin: Firmware Version: 010A
INFO: Digilent Plugin: JTAG Port Number: 0
INFO: Digilent Plugin: JTAG Clock Frequency: 6000000 Hz
INFO: Successfully opened Digilent USB JTAG Cable
INFO: Cable: Digilent JTAG-SMT1, Port: 0, Speed: 6000000 Hz
ERROR - Device 0: Communication failed with device: 0
INFO: DEV:0 MyDevice0 (XC7K325T) is not configured
However, I am able to burn FPGA using IMPACT tool.
Kindly guide me. I tried to reinstall Xilinx 13.4 but, it is still not working.
Nandish.
Re: Chipscope pro not detecting cabel
Please try reducing the cable speed and see if that helps
Thanks,Vijay
You can also try with disabling the antivirus.
--Syed
Observer nandish
Syed, there is no antivirus and I have already disabled windows firewall.
Hello
Do you have any other devices in the JTAG chain?
Which version of tools are you using? Can you try with ISE 14.7?
Vinay
Observer pjbagde
we had the same problem the reason was we were using  fpga board manifactured by local manifacturer , the problem was solved when we switched to orignal fpga board by digilent Texas Instruments.
Hi @pjbagde ,
Thanks for posting the solution. Please mark the solution in ther interest of other users.
Thanks,Vijay
Observer nandish
No there are no other devices in JTAG chain. I have only lisence for ISE 13.4. Will a 30 days evalution lisence allow me to use Chipscope Pro?
Yes, ISE Design Suite Evaluation license includes ChipScope™ Pro and the ChipScope Pro Serial I/O Toolkit. Please check below link.
http://www.xilinx.com/ise_eval/
Ashish
Observer nandish
I think I should have mentioned it before that initially ChipscopePro was working before on the same machine. My colleague tried to install a 30 days evaluation lisence for Vivado. Then onwards it stopped working. I thought it is because of that so I uninstalled Vivado but the problem continued to persist. Do you think that installing a software with evaluation version while there was already a software with permenant lisence might have created this problem?
