02-26-2016 02:30 AM
I am looking for a way to customize the interface specifications (component.xml) of a Vivado System Generator block which is compiled with the 'IP Catalog' target.
I need this, because I want to change the interface type of some of my Gateway In/Out blocks from data to clock, interrupts, differential signals and so on..
Vivado gives me this warning when synthesizing my project:
[IP_Flow 19-4318] IP-XACT file does not exist: d:/clients/rtds/ip_repo/rtds_v1_2/component.xml. It will be created.
Is it possible to provide a custom component.xml which is used by default?
Thanks in advance.
03-02-2016 02:15 AM
Okay, I found a workaround by creating a custom compilation target as described in UG897 (chapter 8).
By using a custom compilation target, I am able to add my own TCL commands before / after Vivado project creation.
Vivado provides a TCL namespace called 'ipx::*' with a bunch of useful commands to adjust your IP-XACT interfaces, package the IP and more..
02-28-2016 03:18 AM
I had same requirement in MIG IP to divide low and high address to DDR.
For that I have made a local copy of MIG and edited component.xml. Later, added this modified IP to IP repository of tool and used it.
So it is possible to edit component.xml.
Praveen
02-28-2016 10:28 AM
Hi Praveen,
Okay, I already used the same workaround by re-packaging the IP again and editing component.xml with the IP-XACT editor.
I was wondering if there's maybe a way integrate this into my workflow without re-packaging my IP after every change.
Steffen
PS: could you please move this topic to the SysGen section of this forum? Sorry, this was my first post..
03-02-2016 02:15 AM
