nag.chil
Data not received PCIe
Iam Following the XAPP1052 and doing a pcie bmd communication.
I am trying to send the data to pc and read via PCIe.
I have inserted ILA core also to see trn level transactions.
I can see in ILA the transaction is being performed...but when i read from PC iam not able to get data..
So What can be the problem.....??
nag.chil
The above problem is solved....
Because of violating pcie protocol that TLP is discarded...so no data i can see in PC...
nag.chil
