Anonymous
Not applicable
Dealy getting data from ROM
I was trying to read the data from ROM. Works perfectly fine except first 100 nano seconds . Data is not loaded from the from. There is a delay. Here is my code and the test bench.  In main source oClock is just a dangling wire don't mind it.simulation.PNGadder.PNGpc counter.PNGtestbench.PNG
main.PNGHhhh
Anonymous
Not applicable
I forgot to mention in above text that I created a single port ROM using IPCATALOG. Thank you in advance,
This is expected behavior. First 100 ns are the initial delay it calculated by cclk frequency to model hardware behavior . You can assert reset for few clock cycles
Thanks and Regards
Balkrishan
Hi @Anonymous
GSR will be active during first 100ns hence you should not issue any read command before 100ns. Hope this clarifies.
Deepika.
Anonymous
Not applicable
Thanks Deepika!
  i though of delalaing two cycles using D-Flipflop but then realied I will still have first 4 byte data. I tried reset onption mention by Balkrishan it did not work. Could you please give me some sample code I could get inspired with.
Thank you
Tags (2)
